    error: Pulling is not possible because you have unmerged files.
    39 Posts 2 Posters 14.7k Views 2 Watching
      DazTypeR
      It is called MagicMirror…
      pi@raspberrypi:~/MagicMirror
        sdetweil @DazTypeR
        @DazTypeR ok, show me the log ~/upgrade.log or ~/MagicMirror/installers/upgrade.log
          the upgrade script does this at the beginning
          # if the MagicMirroe folder exists
          if [ -d ~/MagicMirror ]; then
          	# put the log where the script is located
          	logdir=$(dirname $($cmd -f "$0"))
          	# if the script was execute from the web
          	if [[ $logdir != *"MagicMirror/installers"* ]]; then
          		# use the MagicMirror/installers folder
          		cd ~/MagicMirror/installers >/dev/null
          		logdir=$(pwd)
          		cd - >/dev/null
          	fi
          	logfile=$logdir/upgrade.log
            DazTypeR
            I can’t find an upgrade.log either in home or in the MagicMirror/installers folder.
              sdetweil @DazTypeR
              @DazTypeR well then
              so, when u run it it says
              It appears MagicMirror has not been installed on this system
              please run the installer, "raspberry.sh" first
              if so, rerun the script like this
              bash -c -x  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                DazTypeR
                Hang on, I just ran this command…
                Should I have run this command…
                bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)”
                No idea what the bash -c does?
                Would this have made a difference?
                  sdetweil @DazTypeR
                  @DazTypeR yes… if you do it without bash -c, then it downloads the file, and throws it away
                  if you do the bash -c, then it executes the script (single command -c)
                  watch out for the double quotes… sometimes those turn into MS word document quotes, which linux shells don’t like
                    DazTypeR
                    OK, so its official, I am a numpty :)
                    This is what I get now when I run it…
                    the log will be /home/pi/MagicMirror/installers/upgrade.log
                    doing test run = true
                    update log will be in /home/pi/MagicMirror/installers/upgrade.log
                    saving custom.css
                    upgrading from version 2.9.0 to 2.9.0
                    fetching latest revisions
                    bash: line 159: On branch master: command not found
                    there are 28 local files that are different than the master repo
                    .eslintrc.json
                    .gitignore
                    .travis.yml
                    CHANGELOG.md
                    LICENSE.md
                    installers/raspberry.sh
                    js/main.js
                    modules/default/calendar/vendor/ical.js/node-ical.js
                    modules/default/clock/clock.js
                    modules/default/currentweather/currentweather.js
                    modules/default/newsfeed/newsfeed.js
                    modules/default/updatenotification/node_helper.js
                    modules/default/updatenotification/updatenotification.js
                    modules/default/weather/providers/darksky.js
                    modules/default/weather/providers/openweathermap.js
                    modules/default/weather/providers/ukmetoffice.js
                    modules/default/weather/providers/weathergov.js
                    modules/default/weather/weather.js
                    modules/default/weather/weatherprovider.js
                    modules/default/weatherforecast/weatherforecast.js
                    package.json
                    run-start.sh
                    tests/e2e/vendor_spec.js
                    translations/en.json
                    translations/es.json
                    translations/translations.js
                    vendor/package-lock.json
                    package-lock.json
                    any *-lock.json files do not need to be saved
                    do you want to save these files for later (Y/n)?n
                    skipping restore for .eslintrc.json, doing test run
                    skipping restore for .gitignore, doing test run
                    skipping restore for .travis.yml, doing test run
                    skipping restore for CHANGELOG.md, doing test run
                    skipping restore for LICENSE.md, doing test run
                    skipping restore for installers/raspberry.sh, doing test run
                    skipping restore for js/main.js, doing test run
                    skipping restore for modules/default/calendar/vendor/ical.js/node-ical.js, doing test run
                    skipping restore for modules/default/clock/clock.js, doing test run
                    skipping restore for modules/default/currentweather/currentweather.js, doing test run
                    skipping restore for modules/default/newsfeed/newsfeed.js, doing test run
                    skipping restore for modules/default/updatenotification/node_helper.js, doing test run
                    skipping restore for modules/default/updatenotification/updatenotification.js, doing test run
                    skipping restore for modules/default/weather/providers/darksky.js, doing test run
                    skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
                    skipping restore for modules/default/weather/providers/ukmetoffice.js, doing test run
                    skipping restore for modules/default/weather/providers/weathergov.js, doing test run
                    skipping restore for modules/default/weather/weather.js, doing test run
                    skipping restore for modules/default/weather/weatherprovider.js, doing test run
                    skipping restore for modules/default/weatherforecast/weatherforecast.js, doing test run
                    skipping restore for package.json, doing test run
                    skipping restore for run-start.sh, doing test run
                    skipping restore for tests/e2e/vendor_spec.js, doing test run
                    skipping restore for translations/en.json, doing test run
                    skipping restore for translations/es.json, doing test run
                    skipping restore for translations/translations.js, doing test run
                    skipping restore for vendor/package-lock.json, doing test run
                    skipping restore for package-lock.json, doing test run
                    processing dependency changes for active modules with package.json files
                    processing for module MMM-GooglePhotos please wait
                    skipped processing for MMM-GooglePhotos, doing test run
                    processing complete for module MMM-GooglePhotos
                    restoring custom.css
                    It then put me back to the command line.
                      sdetweil @DazTypeR
                      @DazTypeR cool,just like it should have… altho… line 159 bothers me
                      can you run it again without apply, and use the debug flag
                      you will have to scroll back up in the terminal window, but I’d like to see the few lines above/below the error line 159
                      thx
                        DazTypeR
                        Hope this has everything you need…
                        • echo current branch = master
                          ++ git status
                        • ‘On branch master’ ‘Your branch and ‘'‘origin/master’'’ have diverged,’ ‘and have 4 and 76 different commits each, respectively.’ ’ (use “git pull” to merge the remote branch into yours)’ ‘You have unmerged paths.’ ’ (fix conflicts and run “git commit”)’ ’ (use “git merge --abort” to abort the merge)’ ‘Changes to be committed:’ ’ modified: .eslintrc.json’ ’ modified: .gitignore’ ’ modified: .travis.yml’ ’ modified: CHANGELOG.md’ ’ modified: LICENSE.md’ ’ deleted: css/custom.css’ ’ modified: installers/raspberry.sh’ ’ modified: js/main.js’ ’ modified: modules/default/calendar/vendor/ical.js/node-ical.js’ ’ modified: modules/default/clock/clock.js’ ’ modified: modules/default/currentweather/currentweather.js’ ’ modified: modules/default/newsfeed/newsfeed.js’ ’ modified: modules/default/updatenotification/node_helper.js’ ’ modified: modules/default/updatenotification/updatenotification.js’ ’ modified: modules/default/weather/providers/darksky.js’ ’ modified: modules/default/weather/providers/openweathermap.js’ ’ modified: modules/default/weather/providers/ukmetoffice.js’ ’ modified: modules/default/weather/providers/weathergov.js’ ’ modified: modules/default/weather/weather.js’ ’ modified: modules/default/weather/weatherprovider.js’ ’ modified: modules/default/weatherforecast/weatherforecast.js’ ’ modified: package.json’ ’ modified: run-start.sh’ ’ new file: tests/configs/modules/weather/currentweather_default.js’ ’ new file: tests/configs/modules/weather/currentweather_options.js’ ’ new file: tests/configs/modules/weather/currentweather_units.js’ ’ new file: tests/configs/modules/weather/forecastweather_default.js’ ’ new file: tests/configs/modules/weather/forecastweather_options.js’ ’ new file: tests/e2e/modules/mocks/index.js’ ’ new file: tests/e2e/modules/mocks/weather_current.js’ ’ new file: tests/e2e/modules/mocks/weather_forecast.js’ ’ new file: tests/e2e/modules/weather_spec.js’ ’ modified: tests/e2e/vendor_spec.js’ ’ new file: tests/node_modules/webdriverajaxstub/index.js’ ’ modified: translations/en.json’ ’ modified: translations/es.json’ ’ new file: translations/ms-my.json’ ’ modified: translations/translations.js’ ’ new file: untrack-css.sh’ ’ modified: vendor/package-lock.json’ ‘Unmerged paths:’ ’ (use “git add …” to mark resolution)’ ’ both modified: package-lock.json’ ‘Untracked files:’ ’ (use “git add …” to include in what will be committed)’ ’ css/save_custom.css’ ’ installers/dumpactivemodules.js’
                          ++ git status
                          ++ grep modified
                          ++ awk -F: ‘{print $2}’
                        • diffs=’ .eslintrc.json
                          .gitignore
                          .travis.yml
                          CHANGELOG.md
                          LICENSE.md
                          js/main.js
                        • 2 / 4
