    MMM-DumpsterDay
    83 Posts 11 Posters 56.1k Views 12 Watching
      Doughboy99 @BD0G
      @BD0G Thanks Ive posted an issue. Your link is to another reposirory for a similar module .
      The correct link is here
      B D 2 Replies Last reply Reply Quote 1
        BD0G @Doughboy99
        @Doughboy99 Corrected the link. Thanks!
          DeanoNoire @Doughboy99
          @Doughboy99 Thanks a lot guys, I just corrected it on github.
          Have a good one!
            BD0G
            Thanks @DeanoNoire . Any plans to implement the “Tomorrow is Trash Day” and “Today is Trash Day” text?
              DeanoNoire @BD0G
              @BD0G wasn’t really planning to, but I guess I can add it as an option :) will see how much work is wating for me at job this week :D
              • P Offline
                Paddi
                @DeanoNoire Had no luck to make it work. When adding in the config.js and restarting mirror it messes up things. Black background instead of usual picture. Some modules do not load…
                Could you help ?
                  BD0G @Paddi
                  @Paddi Try Pressing the CTRL-Shift-i keys together once the Magic Mirror has loaded to bring up the developers window. Then click on the tab labeled console and look for any errors. Usually in Red text. When there is a black screen it “typically” indicates one or more of the modules has crashed.
                    BD0G
                    I had this module working great , but for some strange reason it no longer shows the Landscape can. I set the dates to tommorrow which is trash day so the Trash Can and Landscape can should be displayed the day before (which it today) and only the Trash Can is displayed. My date is set correctly on the Magic Mirror so its not that.
                    Here is my config entry
                    	module:"MMM-DumpsterDay",
                    	position:"bottom_bar",
                    		refreshInterval: 18000000, // Default: 18000000 = 5 hours
                    		pulse: true, 			   // Default: true - Makes the module pulsating
                    		enableBasic: true, 				// Enable basic trashcan
                    		basicStartDate: "27.11.2019", 	// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                    		basicDateDiff_1: 7,			// Trashday reoccurance - Default: 14 (every 14 days)
                    		basicNotifyDayBefore: true,		//Default: true - If you want the notification to appear also the day before the dumpster day
                    		enablePlastic: false,			// Same values as basic but for Plastic
                    		plasticStartDate: "27.11.2019",
                    		plasticDateDiff_1: 28,
                    		plasticNotifyDayBefore: true,
                    		enableLandscape: true,			// Same values as basic but for Landscape
                    		landscapeStartDate: "27.11.2019",
                    		landscapeDateDiff_1: 14,
                    		landscapeNotifyDayBefore: true,
                      DeanoNoire @BD0G
                      @BD0G Can you try updating the latest version of this module from github? :) there was an issue with Landscape part.
                        mrdenmark
                        has anyone managed to get this module to work correctly?i’ve tried allsorts of config options but it behaves quite strangely.
                        my collection day is monday,the red gets collected every monday and the blue and yellow get alternate and get collected biweekly.
                        the module did as it should the first week and never since then,it only shows 1 bin,some weeks it shows a bin to be collected on thursday,dissapears on friday and re-appears on sunday!
                                position:"upper_third",
                                        pulse: false,
                                        maxWidth: "75px",                          // Default: true - Makes the module pulsating
                                        basicStartDate: "11.11.2019",   // The first dumpster day (Always use 2 digit dates (01 instead of 1))
                                        basicNotifyDayBefore: true,             //Default: true - If you want the notification to appear also t$
                                        plasticStartDate: "04.11.2019",
                                        plasticDateDiff_1: 14,
                                        landscapeStartDate: "11.11.2019",
                        • 6
                        • 7
                        • 8
                        • 9
                        • 6 / 9
