    Trouble with changing default holiday/calendar (dutch)
    12 Posts 2 Posters 5.4k Views 2 Watching
    • C Offline
      Christiaan99
      Iam making my first SmartMirror so iam a noobie to this.
      I am having some trouble to change the default holiday/calendar to Dutch.
      I have tried looking up on the website Calendarlaps but can find anything there about the dutch holidays.
      So I went a started googling and found a video on YouTube. He was using a website called officeholidays.com. On this website I found a calender but when i put that url in, its shows nothing other then “Geen geplande afspraken” (No scheduled appointments).
      			header: "Vakantie/Kalender",
      						symbol: "calendar-check",
      						//url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/us_Holidays.ics"
      						url: "webcal:https://www.officeholidays.com/ics/netherlands"
      Also i have some trouble with MMM-NStreinen, MMM-NetwerkScanner, MMM-NowPlayingOnSpotify. If someone know about it let me know!
        sdetweil @Christiaan99
        @Christiaan99 said in Trouble with changing default holiday/calendar (dutch):
        url: “webcal:https://www.officeholidays.com/ics/netherlands”
        remove the
         webcal:
        • C Offline
          Christiaan99 @sdetweil
          @sdetweil Yes, it works only its says that Christmas day over 2 months and thats not correct. How can i change it to a date? and how can i change it to Dutch? its in English now.
            @Christiaan99 the calendar rounds up for elapsed days/weeks/months.
            i do not think the default calendar will display exact dates
            the calendar data is in english, (download and edit the file) the calendar module does not translate.
            • C Offline
              @sdetweil Is there a other calendar you suggest then? i want the full date.
              What do i do after i download the file and change it? Its then local and not a URL anymore
                @Christiaan99 i do not know of a calendar that presents actual dates. there are some calendars like CalendarEex2 that can present a page, like a normal calendar layout
                it was just a test to make sure the URl worked… you can erase the downloaded file
                • C Offline
                  @sdetweil Okay, but I changed the text now but how can i import it to magicmirror then?
                    @Christiaan99 put the cursor in the address field (where the url is) and do ctrl-a, ctrl-c
                    (select all, copy) and then go to the editor for the config, and paste
                    did u get working url?
                    • C Offline
                      @sdetweil When I put the url in Google it downloads by itself. I open it and changed the text to dutch and safed it. Now i have a ICS document with the correct language. How can i get the url of that then?
                      Yes, the URL is working.
                        ah, move the file to the modules/default/calendar folder
                        then the url will be
                        “file:///default/calendar/???.ics”
                        • C Offline
                          @sdetweil i have done tried this now:
                          						//url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/_Holidays.ics",
                          						//url: "https://www.officeholidays.com/ics/netherlands",
                          						file: "///default/calendar/nederland.ics",
                          It gives me a black screen now
                            @Christiaan99 no. The
                            url: "file:///......"
