    Trouble with changing default holiday/calendar (dutch)
    12 Posts 2 Posters 4.7k Views 2 Watching
      sdetweil @Christiaan99
      @Christiaan99 i do not know of a calendar that presents actual dates. there are some calendars like CalendarEex2 that can present a page, like a normal calendar layout
      it was just a test to make sure the URl worked… you can erase the downloaded file
        Christiaan99 @sdetweil
        @sdetweil Okay, but I changed the text now but how can i import it to magicmirror then?
          @Christiaan99 put the cursor in the address field (where the url is) and do ctrl-a, ctrl-c
          (select all, copy) and then go to the editor for the config, and paste
          did u get working url?
            @sdetweil When I put the url in Google it downloads by itself. I open it and changed the text to dutch and safed it. Now i have a ICS document with the correct language. How can i get the url of that then?
            Yes, the URL is working.
              @Christiaan99 said in Trouble with changing default holiday/calendar (dutch):
              ah, move the file to the modules/default/calendar folder
              then the url will be
              “file:///default/calendar/???.ics”
                @sdetweil i have done tried this now:
                			header: "Vakantie/Kalender",
                						symbol: "calendar-check",
                						//url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/_Holidays.ics",
                						//url: "https://www.officeholidays.com/ics/netherlands",
                						file: "///default/calendar/nederland.ics",
                It gives me a black screen now
                  @Christiaan99 no. The
                  url: "file:///......"
