    Trouble with changing default holiday/calendar (dutch)
    12 Posts 2 Posters 4.9k Views 2 Watching
    • C Offline
      Christiaan99 @sdetweil
      @sdetweil Is there a other calendar you suggest then? i want the full date.
      What do i do after i download the file and change it? Its then local and not a URL anymore
        sdetweil @Christiaan99
        @Christiaan99 i do not know of a calendar that presents actual dates. there are some calendars like CalendarEex2 that can present a page, like a normal calendar layout
        it was just a test to make sure the URl worked… you can erase the downloaded file
        • C Offline
          @sdetweil Okay, but I changed the text now but how can i import it to magicmirror then?
            @Christiaan99 put the cursor in the address field (where the url is) and do ctrl-a, ctrl-c
            (select all, copy) and then go to the editor for the config, and paste
            did u get working url?
            • C Offline
              @sdetweil When I put the url in Google it downloads by itself. I open it and changed the text to dutch and safed it. Now i have a ICS document with the correct language. How can i get the url of that then?
              Yes, the URL is working.
                @Christiaan99 said in Trouble with changing default holiday/calendar (dutch):
                ah, move the file to the modules/default/calendar folder
                then the url will be
                “file:///default/calendar/???.ics”
                • C Offline
                  @sdetweil i have done tried this now:
                  			header: "Vakantie/Kalender",
                  						symbol: "calendar-check",
                  						//url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/_Holidays.ics",
                  						//url: "https://www.officeholidays.com/ics/netherlands",
                  						file: "///default/calendar/nederland.ics",
                  It gives me a black screen now
                    @Christiaan99 no. The
                    url: "file:///......"
