    MagicMirror Newsfeed continually "loading"...
    24 Posts 4 Posters 11.4k Views 4 Watching
    • ParvezP Offline
      Parvez
      Just reinstall this modules
      i things solved this problem
      cd ~/MagicMirror/modules/default/newsfeed/
      npm install
      Parvez Ahmed
        sdetweil @Parvez
        @Parvez no. no package.json there
        that is part of the base mm
        • ParvezP Offline
          Parvez
          @sdetweil can you help me … install problem MMM Hotword
          Welcome to Hotword v2.4.0
          Checking OS...
          OS Detected: linux-gnueabihf (raspbian 10 armv7l)
          Do you want to execute automatic intallation ? [Y/n]
          Your choice: N
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm ERR! code E404
          npm ERR! 404 Not Found - GET https://registry.npmjs.org/@bugsounet%2flpcm16 - Not found
          npm ERR! 404
          npm ERR! 404  '@bugsounet/lpcm16@^1.0.1' is not in the npm registry.
          npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
          npm ERR! 404 It was specified as a dependency of 'MMM-Hotword'
          npm ERR! 404
          npm ERR! 404 Note that you can also install from a
          npm ERR! 404 tarball, folder, http url, or git url.
          npm ERR!     /home/pi/.npm/_logs/2020-10-03T05_32_52_379Z-debug.log
          Parvez Ahmed
            sdetweil @Parvez
            @Parvez hotword has been removed, and is no longer available.
            to use GoogleAssistant you have to install MMM-GoogleAssistant
            .also bugsounet has removed some of his modules
