    config
    57 Posts 9 Posters 32.4k Views 7 Watching
    • G Offline
      geo
      hi when i try to boot mm meesage on screen asking me to create config.it was working and i was fiddling with the weather but dont know what i have done wrong.
      i am not comp savvy and its taken me a long time to get here.
      cheers
      geo
      • FoziF Offline
        Fozi Project Sponsor
        I‘m 100% sure you have a syntax error in your config, very likely a missing comma or a bracket. The error message is some what misleading. Post your config and we‘ll look on it.
        S G 2 Replies Last reply Reply Quote 0
          sdetweil @Fozi
          @Fozi @geo
          do
          cd ~/MagicMirror
          npm run config:check
          fix each error, starting from the top, make one change, rerun
          the error is usually reported on the line AFTER the problem
          unexpected token is usually a missing comma on the line before, or missing matched quotes
          • G Offline
            geo @Fozi
            @Fozi hi i am now really embarassed,how do i post tme config.
            i should explain i thought the mirror would be a great project but did not realise ,for me, how complicated it was.
            cheers
            geo
              BD0G
              Stick with it! Its a great learning experience. Just take your time and dont rush.
              Here is how you post your config entries.
              Open the MagicMirror/config/config.js file in a text editor. Highlight the entries in the config file. CTRL-C or copy command. Then come back to the forum and start a reply post. When you want to paste your code click on the little </> icon above the post. You will see a notification in the posting then that reads Code Here. Highlight that Code Here and choose CTRL-V or paste command. That will paste the code. Choose Submit! Done.
              • G Offline
                geo
                code_text
                ```/* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "GB Holidays",
                						symbol: "calendar-check",
                						url: "webcal://www.calendar/embed?src=en.uk%23holiday%40group.v.calendar.google.com"					}
                			module: "compliments",
                			position: "lower_third"
                			module: "currentweather",
                			config:
                				locationID: "53.9576",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				appid: "76b503a29647f3a01dd9ba1055daea6d",
                			module: "weatherforecast",
                			header: "Weather Forecast",
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title:  "BBC",
                						url: "http://WWW.BBC.com/services/xml/rss/bbc/HomePage.xml",
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: false,
                				broadcastNewsUpdates: true,
                B S 2 Replies Last reply Reply Quote 0
                  broberg Project Sponsor @geo
                  you were missing a { after config: under the module currentweather
                  and also one to many , under the module weatherforecast
                  Corrected code :
                    sdetweil @geo
                    @geo said in config:
                      	config:
                    should be
                    			config:  {    // < ---- missing open brace
                    this
                    should be
                    				//,   < ---  remove extra comma
                    • G Offline
                      geo
                      hi and thx again.still no joy and i have poated the latest config```
                      code_text
                       * MIT Licensed.
                      var config = {
                      	port: 8080,
                      	language: "en",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "alert",
                      			position: "top_bar"
                      			module: "clock",
                      			config:  {
                      			module: "newsfeed",
                      			config:
                      				feeds: [
                      						title:  "BBC",
                      S L 2 Replies Last reply Reply Quote 0
                        sdetweil @geo
                        @geo missing the /* as the 1st line
                          @geo here is the fixed up config
                          run thru npm run config:check til no errors
                          missing comma and open {
                           * MIT Licensed.
                          var config = {
                          	port: 8080,
                          	language: "en",
                          	timeFormat: 24,
                          	units: "metric",
                          			module: "alert",
                          			position: "top_bar"
                          			module: "clock",
                          			config:  {
                          			module: "newsfeed",
                          				feeds: [
                          						title:  "BBC",
                          • G Offline
                            geo
                            npm ERR!     /home/pi/.npm/_logs/2019-11-16T14_09_4
                            code_text
                              sdetweil @geo
                              @geo needs to be done from inside the MagicMirror folder…
                              • G Offline
                                geo @sdetweil
                                @sdetweil hi after another attempt i find the config is empty all that is available is the sample
                                  sdetweil @geo
                                  @geo i posted the corrected config.js above, cut/paste it back into the ~/MagicMiror/config/config.js file
                                  • G Offline
                                    geo @geo
                                    @geo would it be better to delete and re install
                                      sdetweil @geo
                                      @geo no… just missing the config file…
                                      select the text in my post above, right click mouse, select copy,
                                      then open an editor on the file and right click mouse paste
                                      i use ssh and BitVise ssh client so I can access and edit files thru my windows machine
                                      • G Offline
                                        geo @sdetweil
                                        @sdetweil hi sorry but i am stuck config.js is empty and cant find text editor
                                          sdetweil @geo
                                          @geo nano is a text editor
                                          you can also do
                                          cp config.js.sample config.js
                                          to copy the initial
                                          • G Offline
                                            geo
                                            totally totally out of my depth and do not understand why my config.js is empty and why the text editor is missing.sorry
                                            • 1 / 3
