    config
    57 Posts 9 Posters 24.0k Views 7 Watching
    • G Offline
      geo @sdetweil
      @sdetweil hi i think i am back on track.you say to cut,is that the same as copy,because when i right click on your config all i see is copy.cheers
        sdetweil @geo
        @geo cut/paste is the generic term for the operations of marking the source, and transferring it to the destination
        copy is the non destructive form of cut
        • G Offline
          geo
          @geo said in config:
          geo
          this is what i have
          /* Magic Mirror Config Sample
           * MIT Licensed.
           * MIT Licensed.
           * See https://github.com/MichMich/MagicMirror#configuration/*
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "GB Holidays",
          						symbol: "calendar-check",
          						url: "webcal://www.calendar/embed?src=en.uk%23holiday%40group.v.calendar.google.com"					}
          			module: "compliments",
          			position: "lower_third"
          			module: "currentweather",
          			config:  {
          				locationID: "53.9576",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: "76b503a29647f3a01dd9ba1055daea6d",
          			module: "weatherforecast",
          			header: "Weather Forecast",
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title:  "BBC",
          						url: "http://WWW.BBC.com/services/xml/rss/bbc/HomePage.xml",
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: false,
          				broadcastNewsUpdates: true,
            sdetweil @geo
            @geo ok… does it work?
            • G Offline
              geo @sdetweil
              @sdetweil no
              • G Offline
                geo
                hi i thought i had managed to copy the config you sent but obviosly not as mirror still will not open ,cheers
                • L Offline
                  La7dan @geo
                  I will make it works dont worry!
                  First reinstall:
                  1- Run this command:
                  sudo rm -R MagicMirror
                  (that will rmove the Magic mirror from your system.
                  2- Run this command:
                  bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
                  to install the new MagicMirror again.
                  3- make sure the config .js is there if not
                  run this command
                  nano MagicMirror/config/config.js
                  then copy between lines:
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	language: "en",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "alert",
                  			position: "top_bar"
                  			module: "clock",
                  			header: "US Holidays",
                  						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                  				locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  				appid: "YOUR_OPENWEATHER_API_KEY"
                  				locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  			module: "newsfeed",
                  				feeds: [
                  						title: "New York Times",
                  				broadcastNewsFeeds: true,
                  end: dont copy the line above ( you can fin the file in config dirctory under the name of config.js.sample. Just save it as config.js without sample)
                  4- start your Magic Mirror
                  First: cd MagicMirror
                  (to navigate to the Magic Mirror dirctory)
                  second run : npm start
                  Check if it works!
                  I will be helping you step by step even if you wants to add some modules.
                  Good luck!!!
                  S Mykle1M G 3 Replies Last reply Reply Quote 0
                    sdetweil @La7dan
                    @La7dan please use the updated installer
                    see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                    it will be part of the next release
                      Mykle1 Project Sponsor Module Developer @La7dan
                      @La7dan
                      Please read and use this guide regarding posting code on the forum. Peace!
                      https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                      • G Offline
                        geo @La7dan
                        @La7dan hi the mirror is up and running.the next problem is to have the weather and news modules changed to Gb
                        • 6
                        • 3 / 6
