    config
    57 Posts 9 Posters 32.4k Views 7 Watching
    • L Offline
      La7dan @geo
      @geo give me the name of the module and the location I will help you to make it works! thank you
      G 2 Replies Last reply Reply Quote 0
      • L Offline
        La7dan @Mykle1
        @Mykle1 Thank you thats help a lot.
        • G Offline
          geo @cowboysdude
          @cowboysdude hi thx for that when you say make a copy where is it saved to.cheers
          • G Offline
            geo @La7dan
            @La7dan hi again firstly the mm no longer opens on boot.
            i have the calander but with us hols.i would like uk weather and news.cheers
            • L Offline
              La7dan @geo
              @geo did you install pm2 ? and follow the instructions ?
              https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
              show me your config so I could fix it. im online for an hour we could get it done
                sdetweil @La7dan
                @La7dan if you use one of the installer scripts… listed on the MM github page, or mine listed here in the forums (see here https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                it will setup pm2, and turn off the screensaver…as part of the mm install…
                  sdetweil @geo
                  @geo where? its up to you…
                  copy it to the same folder as config.js.saved
                  or to another folder
                  or to a server disk,
                  or to a drop box , or google drive
                  depends on how ‘safe’ you want to be…
                  its just a copy command
                  cp config.js config.js.save
                  • G Offline
                    geo @cowboysdude
                    @cowboysdude can it be copied to the config sample
                      sdetweil @geo
                      @geo you do not want to copy over the sample…
                      • G Offline
                        geo @La7dan
                        @La7dan hi,mm not opening now on boot.
                        i have the cal and clock on uk time with us hols,would like the news to be uk,i dont have the weather.
                        thx
                        S L 2 Replies Last reply Reply Quote 0
                        • L Offline
                          La7dan
                          try
                          pm2 start 0
                          is the magicmirror working ?
                          S G 2 Replies Last reply Reply Quote 0
                            sdetweil @geo
                            @geo has it always not been opening on boot?
                            use this script to fix that
                            see here
                            https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
                            if the mm won’t start at all, that is a different problem
                            new on uk… which news source do you want? open their page, and scroll down to the bottom… thy usually list rss feeds
                              sdetweil @La7dan
                              @La7dan just use pm2
                              • L Offline
                                La7dan @sdetweil
                                @sdetweil true service could be confusing
                                • L Offline
                                  La7dan @geo
                                  @geo http://rss.cnn.com/services/podcasting/cnn10/rss.xml
                                  this is an example for CNN news/.
                                    sdetweil @La7dan
                                    @La7dan use the search feature on your favorite news site… here from the bbc, to find an rss feed to put into the news config
                                    https://www.bbc.co.uk/search?q=rss
                                    G 1 Reply Last reply Reply Quote 1
                                    • G Offline
                                      geo @La7dan
                                      @La7dan hi sorry for the delay the mm is up and running
                                      • G Offline
                                        geo @sdetweil
                                        @sdetweil hi can you tell me how and where i can backup the config to in case i make more mistakes cheers
                                          sdetweil @geo
                                          @geo open a terminal window
                                          Then do
                                          cd ~/MagicMirror/config
                                          That saves your current config.js to another file
                                          • G Offline
                                            geo @sdetweil
                                            brilliant thankyou@sdetweil
                                            • 3 / 3
