    config
    57 Posts 9 Posters 33.3k Views 7 Watching
      sdetweil @La7dan
      @La7dan if you use one of the installer scripts… listed on the MM github page, or mine listed here in the forums (see here https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
      it will setup pm2, and turn off the screensaver…as part of the mm install…
        sdetweil @geo
        @geo where? its up to you…
        copy it to the same folder as config.js.saved
        or to another folder
        or to a server disk,
        or to a drop box , or google drive
        depends on how ‘safe’ you want to be…
        its just a copy command
        cp config.js config.js.save
        • G
          geo @cowboysdude
          @cowboysdude can it be copied to the config sample
            sdetweil @geo
            @geo you do not want to copy over the sample…
            • G
              geo @La7dan
              @La7dan hi,mm not opening now on boot.
              i have the cal and clock on uk time with us hols,would like the news to be uk,i dont have the weather.
              thx
              S L 2 Replies Last reply
              • L
                La7dan
                try
                pm2 start 0
                is the magicmirror working ?
                S G 2 Replies Last reply
                  sdetweil @geo
                  @geo has it always not been opening on boot?
                  use this script to fix that
                  see here
                  https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
                  if the mm won’t start at all, that is a different problem
                  new on uk… which news source do you want? open their page, and scroll down to the bottom… thy usually list rss feeds
                    sdetweil @La7dan
                    @La7dan just use pm2
                    L 1 Reply Last reply
                    • L
                      La7dan @sdetweil
                      @sdetweil true service could be confusing
                      • L
                        La7dan @geo
                        @geo http://rss.cnn.com/services/podcasting/cnn10/rss.xml
                        this is an example for CNN news/.
                          sdetweil @La7dan
                          @La7dan use the search feature on your favorite news site… here from the bbc, to find an rss feed to put into the news config
                          https://www.bbc.co.uk/search?q=rss
                          G 1 Reply Last reply
                          • G
                            geo @La7dan
                            @La7dan hi sorry for the delay the mm is up and running
                            • G
                              geo @sdetweil
                              @sdetweil hi can you tell me how and where i can backup the config to in case i make more mistakes cheers
                                sdetweil @geo
                                @geo open a terminal window
                                Then do
                                cd ~/MagicMirror/config
                                That saves your current config.js to another file
                                • G
                                  geo @sdetweil
                                  brilliant thankyou@sdetweil
                                  • G
                                    geo @geo
                                    @geo hi now have the calendar for the uk and the weather for York.any idea how to get the news feed for the uk.cheers
                                      sdetweil @geo
                                      @geo said in config:
                                      I posted yesterday how to find rss feeds for your favorite news source
                                      • G
                                        geo @sdetweil
                                        hi i now have bbc news showing.
                                        thax to all for the great help and patience.
                                        cheers
                                        • L
                                          La7dan @geo
                                          @geo Glad to hear you got it up! Now you gained experince
                                          • G
                                            geo @La7dan
                                            @La7dan thx but still a lot to learn.cheers.
                                            B 1 Reply Last reply
                                            • 3 / 3
