    config
    57 Posts 9 Posters 30.0k Views 7 Watching
    • G Offline
      geo @La7dan
      @La7dan hi again firstly the mm no longer opens on boot.
      i have the calander but with us hols.i would like uk weather and news.cheers
      • L Offline
        La7dan @geo
        @geo did you install pm2 ? and follow the instructions ?
        https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
        show me your config so I could fix it. im online for an hour we could get it done
          sdetweil @La7dan
          @La7dan if you use one of the installer scripts… listed on the MM github page, or mine listed here in the forums (see here https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
          it will setup pm2, and turn off the screensaver…as part of the mm install…
            sdetweil @geo
            @geo where? its up to you…
            copy it to the same folder as config.js.saved
            or to another folder
            or to a server disk,
            or to a drop box , or google drive
            depends on how ‘safe’ you want to be…
            its just a copy command
            cp config.js config.js.save
            • G Offline
              geo @cowboysdude
              @cowboysdude can it be copied to the config sample
                sdetweil @geo
                @geo you do not want to copy over the sample…
                • G Offline
                  geo @La7dan
                  @La7dan hi,mm not opening now on boot.
                  i have the cal and clock on uk time with us hols,would like the news to be uk,i dont have the weather.
                  thx
                  S L 2 Replies Last reply Reply Quote 0
                  • L Offline
                    La7dan
                    try
                    pm2 start 0
                    is the magicmirror working ?
                    S G 2 Replies Last reply Reply Quote 0
                      sdetweil @geo
                      @geo has it always not been opening on boot?
                      use this script to fix that
                      see here
                      https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
                      if the mm won’t start at all, that is a different problem
                      new on uk… which news source do you want? open their page, and scroll down to the bottom… thy usually list rss feeds
                        sdetweil @La7dan
                        @La7dan just use pm2
                        • L Offline
                          La7dan @sdetweil
                          @sdetweil true service could be confusing
                          • L Offline
                            La7dan @geo
                            @geo http://rss.cnn.com/services/podcasting/cnn10/rss.xml
                            this is an example for CNN news/.
                              sdetweil @La7dan
                              @La7dan use the search feature on your favorite news site… here from the bbc, to find an rss feed to put into the news config
                              https://www.bbc.co.uk/search?q=rss
                              G 1 Reply Last reply Reply Quote 1
                              • G Offline
                                geo @La7dan
                                @La7dan hi sorry for the delay the mm is up and running
                                • G Offline
                                  geo @sdetweil
                                  @sdetweil hi can you tell me how and where i can backup the config to in case i make more mistakes cheers
                                    sdetweil @geo
                                    @geo open a terminal window
                                    Then do
                                    cd ~/MagicMirror/config
                                    That saves your current config.js to another file
                                    • G Offline
                                      geo @sdetweil
                                      brilliant thankyou@sdetweil
                                      • G Offline
                                        geo @geo
                                        @geo hi now have the calendar for the uk and the weather for York.any idea how to get the news feed for the uk.cheers
                                          sdetweil @geo
                                          @geo said in config:
                                          I posted yesterday how to find rss feeds for your favorite news source
                                          • G Offline
                                            geo @sdetweil
                                            hi i now have bbc news showing.
                                            thax to all for the great help and patience.
                                            cheers
                                            • 3 / 3
