    config
    57 Posts 9 Posters 33.3k Views 7 Watching
      sdetweil @geo
      @geo you do not want to copy over the sample…
      • G
        geo @La7dan
        @La7dan hi,mm not opening now on boot.
        i have the cal and clock on uk time with us hols,would like the news to be uk,i dont have the weather.
        thx
        S L 2 Replies Last reply
        • L
          La7dan
          try
          pm2 start 0
          is the magicmirror working ?
          S G 2 Replies Last reply
            sdetweil @geo
            @geo has it always not been opening on boot?
            use this script to fix that
            see here
            https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
            if the mm won’t start at all, that is a different problem
            new on uk… which news source do you want? open their page, and scroll down to the bottom… thy usually list rss feeds
              sdetweil @La7dan
              @La7dan just use pm2
              L 1 Reply Last reply
              • L
                La7dan @sdetweil
                @sdetweil true service could be confusing
                • L
                  La7dan @geo
                  @geo http://rss.cnn.com/services/podcasting/cnn10/rss.xml
                  this is an example for CNN news/.
                    sdetweil @La7dan
                    @La7dan use the search feature on your favorite news site… here from the bbc, to find an rss feed to put into the news config
                    https://www.bbc.co.uk/search?q=rss
                    G 1 Reply Last reply
                    • G
                      geo @La7dan
                      @La7dan hi sorry for the delay the mm is up and running
                      • G
                        geo @sdetweil
                        @sdetweil hi can you tell me how and where i can backup the config to in case i make more mistakes cheers
                          sdetweil @geo
                          @geo open a terminal window
                          Then do
                          cd ~/MagicMirror/config
                          cp config.js config.js.save
                          That saves your current config.js to another file
                          • G
                            geo @sdetweil
                            brilliant thankyou@sdetweil
                            • G
                              geo @geo
                              @geo hi now have the calendar for the uk and the weather for York.any idea how to get the news feed for the uk.cheers
                                sdetweil @geo
                                @geo said in config:
                                I posted yesterday how to find rss feeds for your favorite news source
                                • G
                                  geo @sdetweil
                                  hi i now have bbc news showing.
                                  thax to all for the great help and patience.
                                  cheers
                                  • L
                                    La7dan @geo
                                    @geo Glad to hear you got it up! Now you gained experince
                                    • G
                                      geo @La7dan
                                      @La7dan thx but still a lot to learn.cheers.
                                      B 1 Reply Last reply
                                        bhepler Module Developer @geo
                                        @geo - We all went through the same process. You’ll get there.
                                        • 3 / 3
