    config
    57 Posts 9 Posters 33.3k Views 7 Watching
      sdetweil @geo
      @geo has it always not been opening on boot?
      use this script to fix that
      see here
      https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
      if the mm won’t start at all, that is a different problem
      new on uk… which news source do you want? open their page, and scroll down to the bottom… thy usually list rss feeds
        sdetweil @La7dan
        @La7dan just use pm2
        L 1 Reply Last reply
        • L
          La7dan @sdetweil
          @sdetweil true service could be confusing
          • L
            La7dan @geo
            @geo http://rss.cnn.com/services/podcasting/cnn10/rss.xml
            this is an example for CNN news/.
              sdetweil @La7dan
              @La7dan use the search feature on your favorite news site… here from the bbc, to find an rss feed to put into the news config
              https://www.bbc.co.uk/search?q=rss
              G 1 Reply Last reply
              • G
                geo @La7dan
                @La7dan hi sorry for the delay the mm is up and running
                • G
                  geo @sdetweil
                  @sdetweil hi can you tell me how and where i can backup the config to in case i make more mistakes cheers
                    sdetweil @geo
                    @geo open a terminal window
                    Then do
                    cd ~/MagicMirror/config
                    cp config.js config.js.save
                    That saves your current config.js to another file
                    • G
                      geo @sdetweil
                      brilliant thankyou@sdetweil
                      • G
                        geo @geo
                        @geo hi now have the calendar for the uk and the weather for York.any idea how to get the news feed for the uk.cheers
                          sdetweil @geo
                          @geo said in config:
                          I posted yesterday how to find rss feeds for your favorite news source
                          • G
                            geo @sdetweil
                            hi i now have bbc news showing.
                            thax to all for the great help and patience.
                            cheers
                            • L
                              La7dan @geo
                              @geo Glad to hear you got it up! Now you gained experince
                              • G
                                geo @La7dan
                                @La7dan thx but still a lot to learn.cheers.
                                B 1 Reply Last reply
                                  bhepler Module Developer @geo
                                  @geo - We all went through the same process. You’ll get there.
                                  • 3 / 3
