    Compliments issue
    4 Posts 3 Posters 914 Views 3 Watching
    • T
      tintkovich
      Hi guys!
      I edited compliments.js file in /modules/default/compliments cataloge. After that my mirror has stopped displaying this module. I restored the original version and made the modifications to the config.js file.
      It still doesn’t work :/ what can I do?
        sdetweil @tintkovich
        @tintkovich what doesn’t work? Mirror or just compliments?
        Did u put the list if compliments thru a JavaScript parser online?
        • T
          tintkovich @sdetweil
          @sdetweil Hi, Compliments doesn’t work…
          Yes, I did put it thru js parser.
          /* global Log, Module, moment */
          /* Magic Mirror
           * Module: Compliments
           * MIT Licensed.
          Module.register("compliments", {
          	// Module config defaults.
          	defaults: {
          			compliments: {
          		anytime: [
          			"Hey there sexy!"
          		morning: [
          			"Good morning, handsome!",
          			"Enjoy your day!",
          			"How was your sleep?"
          		afternoon: [
          			"Hello, beauty!",
          			"You look sexy!",
          			"Looking good today!"
          		evening: [
          			"Wow, you look hot!",
          			"You look nice!",
          			"Hi, sexy!"
          		updateInterval: 30000,
          		remoteFile: null,
          		fadeSpeed: 4000,
          		morningStartTime: 3,
          		morningEndTime: 12,
          		afternoonStartTime: 12,
          		afternoonEndTime: 17
          	// Set currentweather from module
          	currentWeatherType: "",
          	// Define required scripts.
          	getScripts: function() {
          		return ["moment.js"];
          	// Define start sequence.
          	start: function() {
          		Log.info("Starting module: " + this.name);
          		this.lastComplimentIndex = -1;
          		var self = this;
          		if (this.config.remoteFile !== null) {
          			this.complimentFile(function(response) {
          				self.config.compliments = JSON.parse(response);
          				self.updateDom();
          		// Schedule update timer.
          		setInterval(function() {
          			self.updateDom(self.config.fadeSpeed);
          		}, this.config.updateInterval);
          	/* randomIndex(compliments)
          	 * Generate a random index for a list of compliments.
          	 * argument compliments Array<String> - Array with compliments.
          	 * return Number - Random index.
          	randomIndex: function(compliments) {
          		if (compliments.length === 1) {
          			return 0;
          		var generate = function() {
          			return Math.floor(Math.random() * compliments.length);
          		var complimentIndex = generate();
          		while (complimentIndex === this.lastComplimentIndex) {
          		this.lastComplimentIndex = complimentIndex;
          		return complimentIndex;
          	/* complimentArray()
          	 * Retrieve an array of compliments for the time of the day.
          	 * return compliments Array<String> - Array with compliments for the time of the day.
          	complimentArray: function() {
          		var hour = moment().hour();
          		var compliments;
          		if (hour >= this.config.morningStartTime && hour < this.config.morningEndTime && this.config.compliments.hasOwnProperty("morning")) {
          			compliments = this.config.compliments.morning.slice(0);
          		} else if (hour >= this.config.afternoonStartTime && hour < this.config.afternoonEndTime && this.config.compliments.hasOwnProperty("afternoon")) {
          			compliments = this.config.compliments.afternoon.slice(0);
          		} else if(this.config.compliments.hasOwnProperty("evening")) {
          			compliments = this.config.compliments.evening.slice(0);
          		if (typeof compliments === "undefined") {
          			compliments = new Array();
          		if (this.currentWeatherType in this.config.compliments) {
          			compliments.push.apply(compliments, this.config.compliments[this.currentWeatherType]);
          		compliments.push.apply(compliments, this.config.compliments.anytime);
          		return compliments;
          	/* complimentFile(callback)
          	 * Retrieve a file from the local filesystem
          	complimentFile: function(callback) {
          		var xobj = new XMLHttpRequest(),
          			isRemote = this.config.remoteFile.indexOf("http://") === 0 || this.config.remoteFile.indexOf("https://") === 0,
          			path = isRemote ? this.config.remoteFile : this.file(this.config.remoteFile);
          		xobj.overrideMimeType("application/json");
          		xobj.open("GET", path, true);
          		xobj.onreadystatechange = function() {
          			if (xobj.readyState === 4 && xobj.status === 200) {
          				callback(xobj.responseText);
          		xobj.send(null);
          	 * Retrieve a random compliment.
          	 * return compliment string - A compliment.
          	randomCompliment: function() {
          		var compliments = this.complimentArray();
          		var index = this.randomIndex(compliments);
          		return compliments[index];
              // Override dom generator.
              getDom: function () {
                  var complimentText = this.randomCompliment();
                  var compliment = document.createTextNode(complimentText);
                  wrapper.className = this.config.classes ? this.config.classes : "thin xlarge bright pre-line";
                  wrapper.appendChild(compliment);
                  return wrapper;
              // From data currentweather set weather type
              setCurrentWeatherType: function (data) {
                  var weatherIconTable = {
                      "01d": "day_sunny",
                      "02d": "day_cloudy",
                      "03d": "cloudy",
                      "04d": "cloudy_windy",
                      "09d": "showers",
                      "10d": "rain",
                      "11d": "thunderstorm",
                      "13d": "snow",
                      "50d": "fog",
                      "01n": "night_clear",
                      "02n": "night_cloudy",
                      "03n": "night_cloudy",
                      "04n": "night_cloudy",
                      "09n": "night_showers",
                      "10n": "night_rain",
                      "11n": "night_thunderstorm",
                      "13n": "night_snow",
                      "50n": "night_alt_cloudy_windy"
                  this.currentWeatherType = weatherIconTable[data.weather[0].icon];
              // Override notification handler.
              notificationReceived: function (notification, payload, sender) {
                  if (notification === "CURRENTWEATHER_DATA") {
                      this.setCurrentWeatherType(payload.data);
          • T
            tanvir586 @tintkovich
            @tintkovich
            Delete extra } after the evening section.
