Complete Newb need help running
when i try to run Magic Mirror it gives me a nice little series of “error”
Failed at the magicmirror@2.9.0 start script
This is most likely a problem with the magic mirror package
Not with the npm itself
Tell the author that this fails on your system
sh run-start.sh
System: Linux 4.9.35-v7+
command: “/usr/bin/nodejs” “usr/bin/npm” “start”
node version: 0.10.29
npm version: 1.4.21
code: ELIFECYCLE
“this might be due to the use of legacy binary “node” -
@Apollodus please try the updated installer, your node and npm versions are WAY downlevel
node version: 0.10.29 should be 10. something
npm version: 1.4.21 should be 6. somethinghttps://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
delete the MagicMirror folder and run the script referenced in the topic link above
@sdetweil thank you!!!
