    Initial Setup Q's and Some Doc Feedback
    21 Posts 3 Posters 9.1k Views 3 Watching
    • E Offline
      ember1205 @sdetweil
      @sdetweil said in Initial Setup Q's and Some Doc Feedback:
      @ember1205 said in Initial Setup Q's and Some Doc Feedback:
      Backing up just a bit, there appears to be no guidance in the install doc as to whether I should choose to allow the installer to set MM to autostart and/or whether I should disable the screensaver during the install process. I chose “N” and “Y” respectively.
      that is all really choice on your installation and and usage planning…
      i don’t want to touch the mirror… if it reboots cause of power outage, etc, I want it to logon, and start mirror, and never screen lock…
      so, set OS to auto logon (manual step)
      use pm2 to autostart
      and turn off screensaver
      Yes. Those were all done. But, the screensaver disable was done during the install and it appears to not have modified the same files as the manual changes show.
      S D 2 Replies Last reply Reply Quote 0
        sdetweil @ember1205
        @ember1205 i didn’t set the OpenGL driver… not worth the hassle. the driver is REALLY useful for algorithmic objects, rotating in 3d… nothing we do on the mirror
          sdetweil @ember1205
          hm… i didn’t update the doc for manual install for my new installer… there are just too many places with different solutions…
          I embodied all that I know about and generalized to attempt to cover more as time goes on.
            dsegel @ember1205
            @ember1205 There are three locations where the screensaver might be starting from, and only one of them is actually run (I believe the first found in this order):
            /home/pi/.config/lxsession/LXDE-pi/autostart
            /etc/xdg/lxsession/LXDE-pi/autostart
            /etc/xdg/lxsession/LXDE/autostart
            Raspbian recently changed to not having the first one, so the second is now the preferred method.
            S E 2 Replies Last reply Reply Quote 0
              sdetweil @dsegel
              @dsegel thx… already in the updated installer and the screensaver fixer scripts
              • E Offline
                ember1205 @dsegel
                @dsegel said in Initial Setup Q's and Some Doc Feedback:
                So… None of that works. The ONLY way I could get the screensaver to shut off was to do:
                sudo apt install xscreensaver
                And then run the Screensaver Preferences setup and set it to disabled. Anything else I tried ultimately allowed the screen to go blank (black) after about 15 minutes.
                  sdetweil @ember1205
                  @ember1205 thanks… I wished we had worked on it a little more…
                  i have a script that just does setting screensaver off…
                  haven’t had it fail on anything in a while… just tested Zorin OS. it worked properly
                  • E Offline
                    ember1205 @sdetweil
                    I’m going to try a fresh build and will use your script to see how it fares on this exact version of Raspbian…
                      sdetweil @ember1205
                      @ember1205 k… let me know
                      • E Offline
                        ember1205
                        I have started my new build from scratch and used your install script.
                        There are a number of ‘vulnerability’ warnings that show, and I’m curious if I should actually try and repair them with the suggested npm commands or not.
                        Also, so far, the screensaver does seem to be disabled, but I haven’t yet jumped into the MM configuration to put in place the same modules I had been using on the other setup as of yet.
                        • 3 / 3
