Navigation
    • Search
    Weather module does not work (Please set the correct openweather appid in the...)
    Troubleshooting
    • K
      Klinge last edited by
      I am a complete newbie to raspberry pi. I installed the MagicMirror and now I have problems with the weather module.
      When I start the MagicMirror I get the following error
      Please set the correct openweather appid in the…
      I have searched here in the forum, but I did not find a solution to my concrete problem.
      The code in my config.js
          module: 'currentweather',
                          position: 'top_right',
                                  appid: '5128581'
                          module: 'weatherforecast',
                          header: 'Wettervorhersage',
                                  locationID: '5128581',  //ID from http://www.openweathermap.org
                      appid: '5128581'
      Is it interesting, that I start the MagicMirror in Germany?
      Thanks for helping me.
      • yawns
        yawns Moderator last edited by
        As the config file suggests you need to go to http://www.openweathermap.org and request an appid from there.
        • K
          Thanks for your answer.
          But I did it. In my example is the correct New York appid.
          • yawns
            Not really.
            There is a locationID to identify your location if you don’t use the location name field.
            In addition you need an appid. Therefore you go to http://www.openweathermap.org, click on “Sign up” on the top and create an account. Afterwards you can generate a unique appid which should not be shown to anyone and is tight to your useraccount.
            • K
              Ah, ok! I misunderstood the logic of appid. Now it works!
              Thanks for your help!
