    touch screen
    6 Posts 3 Posters 2.8k Views 3 Watching
      Artech
      Re: touch screen
      you want to display a cursor on your mirror or you you want to do a touchscreen miror?
      • T Offline
        tpot
        both basically if you get the mouse working then touchscreen works. But really i want to know how to get the mouse to show up on the screen
          sdetweil @tpot
          @tpot edit the main.css and comment out this
          html {
            cursor: none;   // < ---
            overflow: hidden;
            background: #000;
          I don’t know if this will override if placed in custom.css
          • T Offline
            tpot @sdetweil
            @sdetweil thanks man cant believe i missed that code thanks alot :)
            • T Offline
              tpot
              this is probably a really easy thing but i cant find out how to do it. How do you create a clickable button ?
                sdetweil @tpot
                @tpot in html this is < button id=“xyz” onclick=“someroutine”>
                someroutine is in your javascript module.js handler
                someroutine: function(){
                the ‘this’ variable points to the button object that caused the call
                this.id equals ‘xyz’
                you can also create the button with code (in the getDom function)
                let button = document.createElement(“button”)
                button.id=‘xyz’;
                button.addEventListener(‘click’,self.someroutine)
                wrapper.appendChild(button)
                here is a routine from another module to create a button object with an icon, and some data (src attribute) to be used when the button is pushed
                	createVideoButton: function(video, height, width) {
                			let button = document.createElement("button");
                			button.className = "button";
                		    button.setAttribute("data-video-src", "modules/" + self.name + "/" + this.config.videoDir + "/" + video);
                		    button.addEventListener("click", self.swapVideo);
                			let img = document.createElement("img");
                			img.src = "modules/" + self.name + "/" + this.config.posterDir + "/" + self.Hash[video.substring(0, video.indexOf('.'))];
                			img.width = width;
                			img.height = height;
                		    button.appendChild(img);
                		return button;
                	swapVideo: function () {
                		Log.log("in handler for button="+this.getAttribute("data-video-src"));
                		self.player.src = this.getAttribute("data-video-src");
                		self.player.load();
                		self.player.controls = true;
                		self.player.play();
