    restart loop without error
    15 Posts 2 Posters 4.3k Views 2 Watching
    • E Offline
      efevee
      Have restart loop with MM v2.9.0.
      Running RPi3:
      Linux magicpi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
      Logs show nothing special:
      1|mm       | Initializing new module helper ...
      1|mm       | Module helper loaded: MMM-NetworkScanner
      1|mm       | Module helper loaded: MMM-Remote-Control
      1|mm       | All module helpers loaded.
      1|mm       | Starting server on port 8080 ...
      1|mm       | Server started ...
      1|mm       | Connecting socket for: calendar
      1|mm       | Starting node helper for: calendar
      1|mm       | Connecting socket for: MMM-DarkSkyForecast
      1|mm       | ====================== Starting node_helper for module [MMM-DarkSkyForecast]
      1|mm       | Connecting socket for: MMM-xiaomi
      1|mm       | Starting xiaomi helper
      1|mm       | Connecting socket for: newsfeed
      1|mm       | Starting module: newsfeed
      1|mm       | Connecting socket for: MMM-NetworkScanner
      1|mm       | Starting module: MMM-NetworkScanner
      1|mm       | Connecting socket for: MMM-Remote-Control
      1|mm       | Starting node helper for: MMM-Remote-Control
      1|mm       | Sockets connected & modules started ...
      1|mm       | > magicmirror@2.9.0 start /home/pi/MagicMirror
      1|mm       | > sh run-start.sh
      1|mm       | Starting MagicMirror: v2.9.0
      1|mm       | Loading config ...
      1|mm       | Loading module helpers ...
      1|mm       | No helper found for module: alert.
      1|mm       | No helper found for module: clock.
      1|mm       | Module helper loaded: calendar
      1|mm       | No helper found for module: MMM-WeeklySchedule.
      1|mm       | Module helper loaded: MMM-DarkSkyForecast
      1|mm       | Module helper loaded: MMM-xiaomi
      1|mm       | Module helper loaded: newsfeed
      1|mm       | No helper found for module: MMM-AirQuality.
      Versions as below:
      pi@magicpi:~/MagicMirror $ node -v
      v10.18.0
      pi@magicpi:~/MagicMirror $ npm -v
      6.13.4
      How to troubleshoot ? Where / how to look for error?
      Tried with sample config.js bu ended same way, with reboot loop…
        sdetweil @efevee
        @efevee pm2 will restart the app if it terminates, so
        do this
        pm2 stop 0
        then
        cd ~/MagicMirror
        npm start
        report any errors
        • E Offline
          efevee
          I/m over SSH, having RPi connected to HDMI monitor so I ran as below.
          Ended with command line prompt, no change on display… MM didn’t run.
          pi@magicpi:~/MagicMirror $ DISPLAY=:0 npm start
          > sh run-start.sh
          Loading config ...
          Server started ...
            sdetweil @efevee
            @efevee interesting… new behavior…
            how did you install? manually or one of the install scripts?
            • E Offline
              efevee
              Official RPi script, however some time ago (two or three MM versions ago)
              From “strange” tweaks I only have only log2ram to extend SD card life:
              Filesystem     1K-blocks    Used Available Use% Mounted on
              /dev/root       14812720 6866740   7281424  49% /
              devtmpfs          342320       0    342320   0% /dev
              tmpfs             473904       0    473904   0% /dev/shm
              tmpfs             473904    6576    467328   2% /run
              tmpfs               5120       4      5116   1% /run/lock
              tmpfs             473904       0    473904   0% /sys/fs/cgroup
              log2ram            40960     328     40632   1% /var/log
              tmpfs              30720       0     30720   0% /home/pi/.pm2/logs
              tmpfs              51200       4     51196   1% /tmp
              /dev/mmcblk0p1     42137   22855     19282  55% /boot
              tmpfs              51200       4     51196   1% /var/hdd.log
              tmpfs              94780       0     94780   0% /run/user/1000
              tmpfs              94780       0     94780   0% /run/user/0
                sdetweil @efevee
                @efevee said in restart loop without error:
                card is not full…
                after the git pull, did u do npm install? and for any modules that have a package.json, do the same in each such module folder (the update script mentioned below does this all for you)
                are u willing to try to update to the latest ? (2.9.0) with the new update script
                see here https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                because u have already attempted update, u will need to add force as a parameter on the end of the url
                (just like the example with apply)
                • E Offline
                  efevee @sdetweil
                  @sdetweil said in restart loop without error:
                  I did…
                  Renamed folder and tried fresh install with another script mentioned on forum but it hanged with “apt-get update” when running as pi user
                  Now upgrading to Buster, however have RPi image two weeks before this behaviour started (haven’t done anything inbetween). When buster fails to fix this issue will reimage sd card and either wait till the issue happens again or will force update to refresh MM as you suggest.
                    sdetweil @efevee
                    was that my new update script?
                    https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                    sometimes the apt-get update takes a while, there is a apt-get upgrade right behind it to actually update the files…
                    apt-get update just updates the list of potential updates
                    • E Offline
                      efevee
                      Yes.
                      Was suprised process takes so long especially I have it all upgraded recently:
                      install starting  - Sun Dec 29 12:57:18 CET 2019
                      installing on armv7l processor system
                      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 9.11 (stretch) Release: 9.11 Codename: stretch
                      ^[[96mUpdating packages ...^[[90m
                      Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB] Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB] Get:3$
                      apt-get update  completed ok
                      install starting  - Sun Dec 29 13:23:04 CET 2019
                      Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB] Hit:3 https://d$
                        sdetweil @efevee
                        stretch
                        stretch is pretty old now… lots of updates
                        • E Offline
                          efevee
                          C’mon… Buster is only for a few months… :)
                          Nevertheless upgrade at 6%, will let you know how it looks like after it finishes.
                            sdetweil @efevee
                            @efevee ok, thx…
                            • E Offline
                              efevee
                              Upgraded to buster, took ages, but seems OK, already had two restarts to check if works constantly. Made sd card dump just in case…
                              pi@magicpi:~ $ pm2 status
                              │ id  │ name   │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                              │ 1   │ mm     │ N/A         │ N/A     │ fork    │ 1541     │ 15h    │ 89   │ online    │ 0%       │ 1.4mb    │ pi       │ disabled │
                              │ 0   │ pir    │ N/A         │ N/A     │ fork    │ 1515     │ 15h    │ 0    │ online    │ 0%       │ 1.5mb    │ pi       │ disabled │
                              wonder for how long will it work…
                                sdetweil @efevee
                                @efevee woohoo!.. thanks for the update…
                                keep an eye on the restarts
                                • E Offline
                                  efevee
                                  think, yesterday after update was 87, two were done on purpose by me to check if it will bring up mm.
                                  number is so high as I used pm2 resurrect to bring pir & mm sessions back from “old” stretch set-up as I have also upgraded pm2 itself…
                                  will report anything suspicious :)
