    Getting update from python code interval-ly
    8 Posts 2 Posters 949 Views 3 Watching
    • N Offline
      ntahlah
      Hello everyone!
      I’m currently trying to create a module that can detect a new people who checks in from my finger print using python module that I have created.
      So far, the module already can display in the attendance however it does not update at all which means that I have to restart the Magic mirror in order to get any new person who comes in.
      The python code that I created can update any new attendance interval-ly but somehow it does not show any update on the mirror.
      Here are the GitHub for the module that I’m currently work on: https://github.com/ntahlahweh/MMM-Attend
      Please do assist me on this matter.
      • N Offline
        ntahlah
        Here are the code I used in my module just in case
        MMM-Attend.js
        Module.register("MMM-Attend",{
        	// Default module config.
        	defaults: {
        		updateInterval: 30000,
        		fadespeed: 4000
         getDom: function() {
            var e = document.createElement("div")
            e.id = "DISPLAY"
            //console.log (test)
            return e
         start: function() {
            Log.info('Starting module: ' + this.name);
          notificationReceived: function(notification, payload, sender) {
            switch(notification) {
              case "DOM_OBJECTS_CREATED":
                var timer = setInterval(()=>{
                  this.sendSocketNotification("GIVE_ME_DATA")
                  //var test = "kel"
                }, 1000)
                break
              case "HERE_IS_DATA":
                var e = document.getElementById("DISPLAY")
                e.innerHTML = payload // display nama
        	var timer = setInterval(() =>{
        	    console.log ("e", e.innerHTML)
                }, 1000)
          getStyles: function() {
              return ['MMM-Attend.css']
        node_helper.js
        /// node_helper.js
        const spawn = require("child_process").spawn
        var NodeHelper = require("node_helper")
        var process = spawn("python", ["/home/pi/MagicMirror/modules/MMM-Attend/attendance.py"])
        var interval = 1000
              case "GIVE_ME_DATA":
                this.job()
                break
          job: function() {
            process.stdout.on("data", (data)=>{
              //var timer = setInterval(() =>{
        	    console.log ("node_helper", data)
                //}, 1000)
              var result = String.fromCharCode.apply(null, new Uint16Array((data)))
              this.sendSocketNotification("HERE_IS_DATA", result)
          sdetweil @ntahlah
          @ntahlah so, you start the python code once.
          and the process.on.stdout() is setup and when it gets data from the python code it will send and update (HERE_IS_DATA)
          but what causes the python code to either run again, or send any update?
          the job function just sets up the stdout handler… but it was setup already
          it doesn’t tell the python code to do anything
          and the node_helper is loaded only once, so the python code is started only once
          • N Offline
            ntahlah
            Hello @sdetweil , thank you for the reply.
            I tried your advice where I use setInterval() in MMM-Attend.js which you could see it here:
            Module.register("MMM-Attend", {
              start: function() {
                setInterval(notificationReceived, 1000); //perform every 1000 milliseconds.
                e.id = "DISPLAY"
                ///console.log("getDom" + )
                return e
                console.log("notificationRecieved")
                    break
            however it gave me error. Is this the way to call it interval-ly? Pardon my Javascript as I really not good at it
              sdetweil @ntahlah
              @ntahlah said in Getting update from python code interval-ly:
              but… that is not the problem
              when the python script does this
                              sendJson = json.dumps(conJson)
              then how does that data get OUT to the thing that started the script? u need to use print to send the stdout,
              so that the process.stdout.on handler will be triggered
              I think you want to uncomment the
                               #print(sendJson)
              then the script will send the json or the "No new staff " on every cycle and the
              function will be triggered
              I also think you want to change the "No new staff message to []
              and also wrap the sendJson in []
              then the modulename.js will get an array of attendents, and if the array is 0 length, there is nothing to do.
              u could check that in the process.stdout.on handler and NOT send an empty message to the modulename.js
              (minimize the work when nothing to do)
              even better, do NOT send any output from python when no new user
              (comment out the # print (“No new staff”) )
              • N Offline
                ntahlah
                @sdetweil ahhh so that seems to be the problem… I thought using
                print("Welcome! \n" + staff_name(int(staff_id)))
                is enough to get the output (since I could get the output from print(“No new staff”)).
                Oh in addition, I also got this
                MaxListenersExceededWarning
                so I put this
                require('events').EventEmitter.defaultMaxListeners = 0;
                inside nodehelper.js (based on my google search) and it seems to run albeitly very slow, well that is something I guess.
                Thanks for the help and advice though.
                  sdetweil @ntahlah
                  @ntahlah u don’t need this but once…
                          this.job()
                          break
                  once u setup the handler in this.job one time. you are done…
                  the handler is set forever (until u unset it, or the process ends)
                  this is why u got the too many handlers problems…
                  so you keep adding a new handler to the list and it gets longer and longer and lonnnnnnger
                  and slower and slower and …
                  • N Offline
                    ntahlah @sdetweil
                    @sdetweil oh I see, I made some modification based on your suggestion
                      socketNotificationReceived: function(notification, payload){
                              process.stderr.on("data", (data)=>{
                              console.log("attend process errorr= "+data)
                                console.log("attend data = "+data)
                            break
                    is this what you mean based on your previous comment. Because I don’t really get it
