    Images & Videos
    19 Posts 2 Posters 15.9k Views 5 Watching
    • Z Offline
      zkab
      More feedback …
      The config should also include ‘imageSize’
      Now the image is full screen and it will hide other information on the screen (despite it is ‘fullscreen_below’)
      It would be good to have it centered with a customized size …
      • U Offline
        Ultimatum22 Module Developer
        Glad you got it working. I might add imageSize in the future, was ment to be a fullscreen photo gallery tho. Does it hide all your modules or just some? It doesn’t hide any modules at my end. I do see that the other modules are very hard to read with the light colors, I am in the progres of customizing that on my mirror.
        • Z Offline
          zkab
          Maybe I gave confusing information to you.
          MMM-RandomBackground doesn’t hide any other modules … what I ment was that some text from other modules are hard to read (light text on light background)
          ‘imageSize’ would solve that problem for me at once
          If you are going to dig in the code please prioritize this before ‘photoDirectories’ … that works OK as a temporay solution
          Thanks …
          • Z Offline
            zkab
            I tested MMM-RandomBackground with 40 images and discovered that very often the same image was chosen two times in row.
            Don’t know how you choose the images order randomly but is there a way to eliminate the random algorithm and just display the images in the file name order they are in the folder …
            • U Offline
              Yeah the random generator isn’t that random with that few of images. Displaying them in order isn’t that difficult. I will add an option for this. Thank you for your feedback, I am working on the css atm.
              I have added an option for displaying random photo’s or in order. Go to ~/MagicMirror/modules/MMM-RandomBackground and do git pull. Then add this to your config, randomOrder: false, Set it to true for random order.
              • Z Offline
                zkab
                Thanks for your reply - I update the software with ‘git pull’
                pi@mirror:~/MagicMirror/modules/MMM-RandomBackground $ git pull
                remote: Counting objects: 5, done.
                remote: Compressing objects: 100% (1/1), done.
                remote: Total 5 (delta 4), reused 5 (delta 4), pack-reused 0
                Unpacking objects: 100% (5/5), done.
                From https://github.com/Ultimatum22/MMM-RandomBackground
                868fc6c…03e3727 master -> origin/master
                Updating 868fc6c…03e3727
                Fast-forward
                .gitignore | 0
                LICENSE | 0
                MMM-RandomBackground.js | 33 ++++++++++++++++++++++++±-------
                node_helper.js | 21 ++++++++++++++++++±-
                package.json | 3 +±
                5 files changed, 46 insertions(+), 11 deletions(-)
                mode change 100644 => 100755 .gitignore
                mode change 100644 => 100755 LICENSE
                My ‘config.js’ looks like this:
                module: ‘MMM-RandomBackground’,
                position: ‘fullscreen_below’,
                randomOrder: false,
                animationSpeed: 100,
                updateInterval: 5000
                But I get only a white screen … have you change the ‘photoDirectories’ also ?
                I still have the link ‘/home/pi/MagicMirror/modules/MMM-RandomBackground/photos’
                • U Offline
                  Did you run npm install? Don’t think the packages have changed but just to be sure. Also the config you pasted is wrong, it’s missing a } at the end, is that just a copy paste error from your side?
                  How do you run MagicMirror, could you try display=:0 npm start dev from the terminal and see for console logs. My mirror works without errors with your config (when I add a } at the end).
                  Or go to :8080 in your browser, press F12 to open dev tools and check for errors.
                  • Z Offline
                    zkab
                    Sorry - my mistake … I forgot to run ‘npm install’
                    Now it works like a Swiss clock …
                    Thanks again
                    • U Offline
                      Good to hear. I did forgot I added some functionality that needed new packages.
