    Images & Videos
    19 Posts 2 Posters 17.4k Views 5 Watching
    • U
      Ultimatum22 Module Developer
      You are installing from the wrong directory, the installer is looking for package.json in your modules folder. You should be in home/pi/MagicMirror/modules/MMM-RandomBackground/
      I just noticed my readme is wrong, after git clone you have to execute cd MMM-RandomBackground.
      • Z
        zkab
        OK - now I got this …
        $ npm install
        magic-mirror-module-random-background@0.0.1 postinstall /home/pi/MagicMirror/modules/MMM-RandomBackground
        ./scripts/post-install.sh
        Post install [in the future this creates a share to photos]
        magic-mirror-module-random-background@0.0.1 /home/pi/MagicMirror/modules/MMM-RandomBackground
        ├── jquery@2.2.4
        └─┬ recursive-readdir@2.1.0
        └─┬ minimatch@3.0.2
        └─┬ brace-expansion@1.1.6
        ├── balanced-match@0.4.2
        └── concat-map@0.0.1
        npm WARN magic-mirror-module-random-background@0.0.1 No repository field.
        But still I don’t get any picture from /nfs/MIRROR … hmmm
        • U
          That looks good. Are you sure that the share is accesable? Try ls -al /nfs/MIRROR on the commandline of your mirror. Does it show any folders and/or photos?
          • Z
            zkab
            Sure it is accessible - I just set up the nfs share myself.
            All the images are listed when I give ls -la /nfs/MIRROR command …
            $ ls -l /nfs/MIRROR/
            total 748
            -rw-rw-r-- 1 pi pi 157448 nov 16 13:18 IMG-20161116-WA0004.jpg
            -rw-rw-r-- 1 pi pi 90988 nov 18 14:07 IMG-20161118-WA0004.jpg
            -rw-rw-r-- 1 pi pi 188982 nov 25 13:30 IMG-20161125-WA0002.jpg
            -rw-rw-r-- 1 pi pi 197352 dec 8 23:55 IMG-20161127-WA0023.jpg
            -rw-rw-r-- 1 pi pi 117901 dec 14 12:01 IMG.jpg
            • U
              My bad, I just realized that the photoDirectories config is not yet implemented. It only reads photo’s from the photos directory in the module itself. You could make a soft link from your share to /home/pi/MagicMirror/modules/MMM-RandomBackground/photos.
              • Z
                zkab
                OK - it worked … but it is a temporary solution
                When are you going to implement photoDirectories config …
                • Z
                  zkab
                  More feedback …
                  The config should also include ‘imageSize’
                  Now the image is full screen and it will hide other information on the screen (despite it is ‘fullscreen_below’)
                  It would be good to have it centered with a customized size …
                  • U
                    Glad you got it working. I might add imageSize in the future, was ment to be a fullscreen photo gallery tho. Does it hide all your modules or just some? It doesn’t hide any modules at my end. I do see that the other modules are very hard to read with the light colors, I am in the progres of customizing that on my mirror.
                    • Z
                      zkab
                      Maybe I gave confusing information to you.
                      MMM-RandomBackground doesn’t hide any other modules … what I ment was that some text from other modules are hard to read (light text on light background)
                      ‘imageSize’ would solve that problem for me at once
                      If you are going to dig in the code please prioritize this before ‘photoDirectories’ … that works OK as a temporay solution
                      Thanks …
                      • Z
                        zkab
                        I tested MMM-RandomBackground with 40 images and discovered that very often the same image was chosen two times in row.
                        Don’t know how you choose the images order randomly but is there a way to eliminate the random algorithm and just display the images in the file name order they are in the folder …
                        • U
                          Yeah the random generator isn’t that random with that few of images. Displaying them in order isn’t that difficult. I will add an option for this. Thank you for your feedback, I am working on the css atm.
                          I have added an option for displaying random photo’s or in order. Go to ~/MagicMirror/modules/MMM-RandomBackground and do git pull. Then add this to your config, randomOrder: false, Set it to true for random order.
                          • Z
                            zkab
                            Thanks for your reply - I update the software with ‘git pull’
                            pi@mirror:~/MagicMirror/modules/MMM-RandomBackground $ git pull
                            remote: Counting objects: 5, done.
                            remote: Compressing objects: 100% (1/1), done.
                            remote: Total 5 (delta 4), reused 5 (delta 4), pack-reused 0
                            Unpacking objects: 100% (5/5), done.
                            From https://github.com/Ultimatum22/MMM-RandomBackground
                            868fc6c…03e3727 master -> origin/master
                            Updating 868fc6c…03e3727
                            Fast-forward
                            .gitignore | 0
                            LICENSE | 0
                            MMM-RandomBackground.js | 33 ++++++++++++++++++++++++±-------
                            node_helper.js | 21 ++++++++++++++++++±-
                            package.json | 3 +±
                            5 files changed, 46 insertions(+), 11 deletions(-)
                            mode change 100644 => 100755 .gitignore
                            mode change 100644 => 100755 LICENSE
                            My ‘config.js’ looks like this:
                            module: ‘MMM-RandomBackground’,
                            position: ‘fullscreen_below’,
                            randomOrder: false,
                            animationSpeed: 100,
                            updateInterval: 5000
                            But I get only a white screen … have you change the ‘photoDirectories’ also ?
                            I still have the link ‘/home/pi/MagicMirror/modules/MMM-RandomBackground/photos’
                            • U
                              Did you run npm install? Don’t think the packages have changed but just to be sure. Also the config you pasted is wrong, it’s missing a } at the end, is that just a copy paste error from your side?
                              How do you run MagicMirror, could you try display=:0 npm start dev from the terminal and see for console logs. My mirror works without errors with your config (when I add a } at the end).
                              Or go to :8080 in your browser, press F12 to open dev tools and check for errors.
                              • Z
                                zkab
                                Sorry - my mistake … I forgot to run ‘npm install’
                                Now it works like a Swiss clock …
                                Thanks again
                                • U
                                  Good to hear. I did forgot I added some functionality that needed new packages.
