    node serveronly works, but npm start doesn't
    5 Posts 2 Posters 1.2k Views 2 Watching
    • N Offline
      nealterrell
      How can I go about diagnosing an issue where node serveronly works fine, but npm start (whether on a terminal or via pm2) fails silently? The only log information from npm is this:
      > magicmirror@2.10.0 start /home/pi/MagicMirror
      > ./run-start.sh
      [15:42:38.586] [LOG]    Starting MagicMirror: v2.10.0
      [15:42:38.595] [LOG]    Loading config ...
      [15:42:38.600] [LOG]    Loading module helpers ...
      [15:42:38.689] [LOG]    Initializing new module helper ...
      [15:42:38.690] [LOG]    Module helper loaded: MMM-Remote-Control
      (process terminates)
      It’s something to do with the MMM-PIR-Sensor module – removing it from config fixes npm start – but the module works fine in node serveronly mode, so I am having trouble identifying the problem.
        sdetweil @nealterrell
        @nealterrell did u install 2.10 or upgrade? Did u use one of the scripts?
        What pi is this
        run-start.sh had been updated to auto detect serveronly in config.js, or on systems where electron doesn’t work.
        Edit the run-start.sh and add a space and -x to the first line
        And then do npm start
        N 2 Replies Last reply Reply Quote 0
        • N Offline
          nealterrell @sdetweil
          @sdetweil Thank you for your reply. Raspberry Pi 4. Initially I upgraded with git pull && npm install, but I found your upgrade script and ran that. Now I added -x to run-start, and this is the output:
          > ./run-start.sh
          + ./untrack-css.sh
          + '[' -z :0.0 ']'
          ++ uname -m
          + arch=armv7l
          + false=false
          ++ grep -v '^\s//' config/config.js
          ++ grep -i serveronly:
          ++ awk '{print tolower($2)}'
          ++ tr -d ',"'\'''
          + serveronly=
          + serveronly=false
          ++ pgrep Xorg
          + xorg=454
          ++ uname
          + mac=Linux
          + '[' false. '!=' false. -o armv7l == armv6l ']'
          + '[' 454. == . -a Linux '!=' Darwin ']'
          + electron js/electron.js
          [17:16:24.796] [LOG]    Starting MagicMirror: v2.10.0
          [17:16:24.810] [LOG]    Loading config ...
          [17:16:24.820] [LOG]    Loading module helpers ...
          [17:16:24.948] [LOG]    Initializing new module helper ...
          [17:16:24.949] [LOG]    Module helper loaded: MMM-Remote-Control
          I added some logging to app.js where it loads modules, and the process terminates on the line Module = require(helperPath) when helperPath is the MMM-PIR-Sensor module.
          I don’t expect you to diagnose every misbehaving module, so I’ll continue to dig and see what went wrong. Any advice would be appreciated; especially regarding why there’s no issue with node serveronly.
          • N Offline
            @sdetweil I found that MMM-PIR-Sensor was failing when requiring onoff, so I wiped its node_modules, npm install, and now everything is fine. Sorry for wasting your time!
              @nealterrell but my script was supposed to run the npm install for you.
              Can u send me the installers/upgrade.log
              Same Id as here on Gmail. Thx
