    MMM-MyTTC hangs at Loading
    8 Posts 2 Posters 2.3k Views 2 Watching
    • T Offline
      TheGeekfather
      Has anyone got this working - such a great module for TTC Toronto. Seems to hang at loading. I’m using the stops provided by Jeff in his config.
      Cheers
      • T Offline
        TheGeekfather @TheGeekfather
        @TheGeekfather
        SOLVED
        Removed bus stop 1048 and it works! Thank you Sam !!
          sdetweil @TheGeekfather
          @TheGeekfather open the developers window, ctrl-shift-i on the keyboard, select the tab labeled console and scroll up to see any errors… usually red text…
          u may also have to see the terminal window (or pm2 logs ) for node_helper related errors
          • T Offline
            TheGeekfather @sdetweil
            Thank you - will try that :)
            • T Offline
              @TheGeekfather
              Getting this message when I start with npm start
              Whoops! There was an uncaught exception…
              [15:30:37.169] [ERROR] TypeError: Cannot read property ‘length’ of undefined
              at Class.processJSON (/home/pi/MagicMirror/modules/default/MMM-MyTTC/node_helper.js:79:29)
              at exports.XMLHttpRequest.xmlHttp.onreadystatechange (/home/pi/MagicMirror/modules/default/MMM-MyTTC/node_helper.js:43:36)
              Not sure what it means
              Thank you for any help
                @TheGeekfather that usually means the apikey is wrong
                • T Offline
                  TheGeekfather
                  Sam, do I get the api key from next bus? Thank you :)
                  • T Offline
                    I don’t see any place to put in api key :(
                    • T Offline
                      @TheGeekfather
                      SOLVED
