    Black screen
    18 Posts 3 Posters 5.3k Views 4 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @Vauxdvihl
      @Vauxdvihl or, from your laptop or pc, you can ssh into the mirror, got to the MagicMirror directory and execute the following for dev mode:
      pm2 stop all
      npm start dev
      See if there are errors coming up in the console.
      Is there still no troubleshooting guide around to reference to?
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • V Offline
        Vauxdvihl
        npm start dev
        results in
        pi@PiMirrorNeu:~ $ npm start dev
        npm ERR! code ENOENT
        npm ERR! syscall open
        npm ERR! path /home/pi/package.json
        npm ERR! errno -2
        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm ERR! enoent This is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR!     /home/pi/.npm/_logs/2020-01-06T19_11_05_569Z-debug.log
          sdetweil @Vauxdvihl
          @Vauxdvihl from the magicmirror folder
          all commands suggested are always from the magic mirror folder
          • V Offline
            Vauxdvihl
            Ah ok
            Sorry
            DevTools was disconnected from the page.
            Once the page is reloaded, DevTools will automatically reconnect.
              sdetweil @Vauxdvihl
              @Vauxdvihl this is still MagicMirror version 2.9?
              a guess
              do
              cd ~/MagicMirror
              git checkout modules/node_modules/node_helper/index.js
              • V Offline
                Vauxdvihl
                Where do i see it?
                Nothing happen:
                pi@PiMirrorNeu:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
                  sdetweil @Vauxdvihl
                  @Vauxdvihl
                  and then restart mirror
                  • V Offline
                    Vauxdvihl
                    Mirror stays black :-(
                      sdetweil @Vauxdvihl
                      @Vauxdvihl if you do
                      cd ~/MagicMirror
                      npm start
                      what do you see on the terminal window?
                      (alt-spacebar, n to minimize MM screen)
                      • V Offline
                        Vauxdvihl
                        pi@PiMirrorNeu:~/MagicMirror $ npm start
                        > magicmirror@2.9.0 start /home/pi/MagicMirror
                        > sh run-start.sh
                        Starting MagicMirror: v2.9.0
                        Loading config ...
                        Loading module helpers ...
                        Module helper loaded: MMM-PublicTransportHafas
                        No helper found for module: MMM-HTMLBox.
                        Module helper loaded: MMM-DarkSkyForecast
                        Module helper loaded: MMM-CalendarExt2
                        Module helper loaded: MMM-BMW-DS
                        No helper found for module: MMM-Globe.
                        No helper found for module: MMM-Timetable.
                        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'del'
                        Require stack:
                        - /home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js
                        App threw an error during load
                        Require stack:
                            at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                            at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                            at Module.require (internal/modules/cjs/loader.js:685:19)
                            at require (internal/modules/cjs/helpers.js:16:16)
                            at Object.<anonymous> (/home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js:3:11)
                            at Module._compile (internal/modules/cjs/loader.js:786:30)
                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                            at Module.load (internal/modules/cjs/loader.js:645:32)
                            at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                        Require stack:
                            at Function.Module._load (internal/modules/cjs/loader.js:560:12) {
                          code: 'MODULE_NOT_FOUND',
                          requireStack: [
                            '/home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js',
                            '/home/pi/MagicMirror/js/app.js',
                            '/home/pi/MagicMirror/js/electron.js',
                            '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                            undefined
                        Launching application.
