    Black screen
    18 Posts 3 Posters 6.3k Views 4 Watching
      sdetweil @Vauxdvihl
      @Vauxdvihl this is still MagicMirror version 2.9?
      a guess
      do
      git checkout modules/node_modules/node_helper/index.js
      • V
        Vauxdvihl
        Where do i see it?
        Nothing happen:
        pi@PiMirrorNeu:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
          sdetweil @Vauxdvihl
          @Vauxdvihl
          and then restart mirror
          • V
            Vauxdvihl
            Mirror stays black :-(
              sdetweil @Vauxdvihl
              @Vauxdvihl if you do
              npm start
              what do you see on the terminal window?
              (alt-spacebar, n to minimize MM screen)
              • V
                Vauxdvihl
                pi@PiMirrorNeu:~/MagicMirror $ npm start
                > magicmirror@2.9.0 start /home/pi/MagicMirror
                > sh run-start.sh
                Starting MagicMirror: v2.9.0
                Loading config ...
                Loading module helpers ...
                Module helper loaded: MMM-PublicTransportHafas
                No helper found for module: MMM-HTMLBox.
                Module helper loaded: MMM-DarkSkyForecast
                Module helper loaded: MMM-CalendarExt2
                Module helper loaded: MMM-BMW-DS
                No helper found for module: MMM-Globe.
                No helper found for module: MMM-Timetable.
                WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'del'
                Require stack:
                - /home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js
                App threw an error during load
                Require stack:
                    at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                    at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                    at Module.require (internal/modules/cjs/loader.js:685:19)
                    at require (internal/modules/cjs/helpers.js:16:16)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js:3:11)
                    at Module._compile (internal/modules/cjs/loader.js:786:30)
                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                    at Module.load (internal/modules/cjs/loader.js:645:32)
                    at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                Require stack:
                    at Function.Module._load (internal/modules/cjs/loader.js:560:12) {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: [
                    '/home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js',
                    '/home/pi/MagicMirror/js/app.js',
                    '/home/pi/MagicMirror/js/electron.js',
                    '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                    undefined
                Launching application.
                  sdetweil @Vauxdvihl
                  @Vauxdvihl Error: Cannot find module ‘del’
                  that will do it
                  do
                  npm install del
                  • V
                    Vauxdvihl
                    What is “del”
                    And why is needed now?
                    Strange
                      sdetweil @Vauxdvihl
                      @Vauxdvihl it was needed by MMM-Weatherchart module, but got deleted on the base update.
                      the automated script cycle was skipped due to the error
                      (this is the WHOLE reason I created the automated script, to cover this very problem)
                      what is it? its some npm library the module uses
                      • V
                        Vauxdvihl
                        Ok
                        Everythings works fine now
