    Black screen
    18 Posts 3 Posters 6.3k Views 4 Watching
      sdetweil @Vauxdvihl
      @Vauxdvihl try keyboard on mirror, ctrl-shift-i to open dev window
      • lavolp3L
        lavolp3 Module Developer @Vauxdvihl
        @Vauxdvihl or, from your laptop or pc, you can ssh into the mirror, got to the MagicMirror directory and execute the following for dev mode:
        pm2 stop all
        npm start dev
        See if there are errors coming up in the console.
        Is there still no troubleshooting guide around to reference to?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • V
          Vauxdvihl
          npm start dev
          results in
          pi@PiMirrorNeu:~ $ npm start dev
          npm ERR! code ENOENT
          npm ERR! syscall open
          npm ERR! errno -2
          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR!     /home/pi/.npm/_logs/2020-01-06T19_11_05_569Z-debug.log
            sdetweil @Vauxdvihl
            @Vauxdvihl from the magicmirror folder
            all commands suggested are always from the magic mirror folder
            • V
              Vauxdvihl
              Ah ok
              Sorry
              DevTools was disconnected from the page.
              Once the page is reloaded, DevTools will automatically reconnect.
                sdetweil @Vauxdvihl
                @Vauxdvihl this is still MagicMirror version 2.9?
                a guess
                do
                git checkout modules/node_modules/node_helper/index.js
                • V
                  Vauxdvihl
                  Where do i see it?
                  Nothing happen:
                  pi@PiMirrorNeu:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
                    sdetweil @Vauxdvihl
                    @Vauxdvihl
                    and then restart mirror
                    • V
                      Vauxdvihl
                      Mirror stays black :-(
                        sdetweil @Vauxdvihl
                        @Vauxdvihl if you do
                        npm start
                        what do you see on the terminal window?
                        (alt-spacebar, n to minimize MM screen)
                        • V
                          Vauxdvihl
                          pi@PiMirrorNeu:~/MagicMirror $ npm start
                          > magicmirror@2.9.0 start /home/pi/MagicMirror
                          > sh run-start.sh
                          Starting MagicMirror: v2.9.0
                          Loading config ...
                          Loading module helpers ...
                          Module helper loaded: MMM-PublicTransportHafas
                          No helper found for module: MMM-HTMLBox.
                          Module helper loaded: MMM-DarkSkyForecast
                          Module helper loaded: MMM-CalendarExt2
                          Module helper loaded: MMM-BMW-DS
                          No helper found for module: MMM-Globe.
                          No helper found for module: MMM-Timetable.
                          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'del'
                          Require stack:
                          - /home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js
                          App threw an error during load
                          Require stack:
                              at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                              at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                              at Module.require (internal/modules/cjs/loader.js:685:19)
                              at require (internal/modules/cjs/helpers.js:16:16)
                              at Object.<anonymous> (/home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js:3:11)
                              at Module._compile (internal/modules/cjs/loader.js:786:30)
                              at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                              at Module.load (internal/modules/cjs/loader.js:645:32)
                              at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                          Require stack:
                              at Function.Module._load (internal/modules/cjs/loader.js:560:12) {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: [
                              '/home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js',
                              '/home/pi/MagicMirror/js/app.js',
                              '/home/pi/MagicMirror/js/electron.js',
                              '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                              undefined
                          Launching application.
                            sdetweil @Vauxdvihl
                            @Vauxdvihl Error: Cannot find module ‘del’
                            that will do it
                            do
                            npm install del
                            • V
                              Vauxdvihl
                              What is “del”
                              And why is needed now?
                              Strange
                                sdetweil @Vauxdvihl
                                @Vauxdvihl it was needed by MMM-Weatherchart module, but got deleted on the base update.
                                the automated script cycle was skipped due to the error
                                (this is the WHOLE reason I created the automated script, to cover this very problem)
                                what is it? its some npm library the module uses
                                • V
                                  Vauxdvihl
                                  Ok
                                  Everythings works fine now
