    Black screen
    18 Posts 3 Posters 5.2k Views 4 Watching
    • V Offline
      Vauxdvihl
      Hi friends,
      i had a running system (everything worked fine)
      I installed “MMM-ip” and changed the config accordingly.
      Now i have a black screen
      I deinstalled the “MMM-ip” but the black screen is still there.
      Can please somebody help?
      Regards
        sdetweil @Vauxdvihl
        @Vauxdvihl Error: Cannot find module ‘del’
        that will do it
        do
        npm install del
        • lavolp3L Offline
          lavolp3 Module Developer @Vauxdvihl
          @Vauxdvihl
          The most probable error is a mistake in your config.
          Please move in the console into your magic mirror folder and execute
          npm run config:check
          OR
          Go on your laptop, open a browser, visit “YOURMAGICMIRRORIP:8080”, press F12 to open Developer Tools, look for errors, post them here. :-)
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • V Offline
            Vauxdvihl
            Config check shows no errors
            and unfortunately does the other thing not work
            Any other debug possibility?
            thanks
            S lavolp3L 2 Replies Last reply Reply Quote 0
              sdetweil @Vauxdvihl
              @Vauxdvihl try keyboard on mirror, ctrl-shift-i to open dev window
              • lavolp3L Offline
                @Vauxdvihl or, from your laptop or pc, you can ssh into the mirror, got to the MagicMirror directory and execute the following for dev mode:
                pm2 stop all
                npm start dev
                See if there are errors coming up in the console.
                Is there still no troubleshooting guide around to reference to?
                • V Offline
                  Vauxdvihl
                  npm start dev
                  results in
                  pi@PiMirrorNeu:~ $ npm start dev
                  npm ERR! code ENOENT
                  npm ERR! syscall open
                  npm ERR! errno -2
                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                  npm ERR! enoent This is related to npm not being able to find a file.
                  npm ERR! enoent
                  npm ERR!     /home/pi/.npm/_logs/2020-01-06T19_11_05_569Z-debug.log
                    sdetweil @Vauxdvihl
                    @Vauxdvihl from the magicmirror folder
                    all commands suggested are always from the magic mirror folder
                    • V Offline
                      Vauxdvihl
                      Ah ok
                      Sorry
                      DevTools was disconnected from the page.
                      Once the page is reloaded, DevTools will automatically reconnect.
                        sdetweil @Vauxdvihl
                        @Vauxdvihl this is still MagicMirror version 2.9?
                        a guess
                        do
                        git checkout modules/node_modules/node_helper/index.js
                        • V Offline
                          Vauxdvihl
                          Where do i see it?
                          Nothing happen:
                          pi@PiMirrorNeu:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
