    Adding shared Google calendars
    4 Posts 2 Posters 4.6k Views 2 Watching
    • C Offline
      cyrus
      I’ve tried to add shared Google calendars, but it just doesn’t show any of the events. I assume it has to do with the credentials. Here’s a copy of my config file for that section. Note that the calendar is not publicly visible and it has to stay that way. Also, I have tried all three options for the “method” section and none seems to make a difference.
      Here’s the config file I’m using:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
              colored: true,
      			     // false, default for all  NON-armv6l devices
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "Customer Schedule",
      						symbol: "calendar-check",
      						url: "https://calendar.google.com/calendar/embed?src=OURDOMAIN.com_XXXXXXXXXXXXXXXXXXXXXXXXX%40group.calendar.google.com",
                                                      auth: {
                                                      user: 'EMAIL@DDR.ESS',
                                                      pass: 'PASSWORD',
                                                      method: 'basic' // I have tried all three options for this
      			module: "currentweather",
      				locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "YOUR_OPENWEATHER_API_KEY"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
        sdetweil @cyrus
        @cyrus u need the public or secret url link of the calendar
        this is not it, this is the embed link
        on the calendar.google.com site, select the calendar lower left, 3 dots,
        select settings
        select integrate calendar
        select either the public address in iCal format, or the secret address in iCal format
        • C Offline
          cyrus
          Thanks for your help. That was indeed the problem.
          S 1 Reply Last reply Reply Quote -1
            sdetweil @cyrus
            @cyrus cool. Glad u got it working!
