    MMM-Screencast erro
    23 Posts 4 Posters 5.1k Views 4 Watching
    • I Offline
      iorifly @sdetweil
      This command worked. now stop underscore error.
      However I have the following error.
      > magicmirror@2.10.0 start /home/pi/MagicMirror
      > ./run-start.sh
      [21:04:03.127] [LOG] Starting MagicMirror: v2.10.0
      [21:04:03.163] [LOG] Loading config ...
      [21:04:03.185] [LOG] Loading module helpers ...
      [21:04:03.191] [LOG] No helper found for module: alert.
      [21:04:03.401] [LOG] Initializing new module helper ...
      [21:04:03.405] [LOG] Module helper loaded: updatenotification
      [21:04:03.408] [LOG] No helper found for module: clock.
      [21:04:04.630] [LOG] Initializing new module helper ...
      [21:04:04.633] [LOG] Module helper loaded: MMM-Screencast
      [21:04:06.010] [LOG] Initializing new module helper ...
      [21:04:06.013] [LOG] Module helper loaded: calendar
      [21:04:06.016] [LOG] No helper found for module: compliments.
      [21:04:07.345] [LOG] Initializing new module helper ...
      [21:04:07.347] [LOG] Module helper loaded: MMM-DarkSkyForecast
      [21:04:07.457] [LOG] Initializing new module helper ...
      [21:04:07.460] [LOG] Module helper loaded: newsfeed
      [21:04:07.548] [LOG] Initializing new module helper ...
      [21:04:07.553] [LOG] Module helper loaded: MMM-HASS
      [21:04:07.557] [LOG] All module helpers loaded.
      [21:04:07.563] [LOG] Starting server on port 8080 ...
      [21:04:07.688] [LOG] Server started ...
      [21:04:07.695] [LOG] Connecting socket for: updatenotification
      [21:04:07.703] [LOG] Connecting socket for: MMM-Screencast
      [21:04:07.710] [LOG] Connecting socket for: calendar
      [21:04:07.716] [LOG] Starting node helper for: calendar
      [21:04:07.721] [LOG] Connecting socket for: MMM-DarkSkyForecast
      [21:04:07.724] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
      [21:04:07.729] [LOG] Connecting socket for: newsfeed
      [21:04:07.734] [LOG] Starting module: newsfeed
      [21:04:07.740] [LOG] Connecting socket for: MMM-HASS
      [21:04:07.745] [LOG] Sockets connected & modules started ...
      [21:04:07.748] [LOG]
      Ready to go! Please point your browser to: http://localhost:8080
      Starting chromium browser now, have patience, it takes a minute
       --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
      events.js:174
            throw er; // Unhandled 'error' event
      Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
          at doWrite (_stream_writable.js:411:19)
          at writeOrBuffer (_stream_writable.js:399:5)
          at Socket.Writable.write (_stream_writable.js:299:11)
          at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46)
          at process.<anonymous> (/home/pi/MagicMirror/js/app.js:40:10)
          at process.emit (events.js:198:13)
          at process._fatalException (internal/bootstrap/node.js:497:27)
      ^C
      PS: Sorry for the delay I was without network for 5 days.
      • I Offline
        iorifly
        @iorifly said in MMM-Screencast erro:
        ./run-start.sh
        [21:04:03.163] [LOG] Loading config …
        [21:04:03.185] [LOG] Loading module helpers …
        [21:04:03.401] [LOG] Initializing new module helper …
        [21:04:04.630] [LOG] Initializing new module helper …
        [21:04:06.010] [LOG] Initializing new module helper …
        [21:04:07.345] [LOG] Initializing new module helper …
        [21:04:07.457] [LOG] Initializing new module helper …
        [21:04:07.548] [LOG] Initializing new module helper …
        [21:04:07.563] [LOG] Starting server on port 8080 …
        [21:04:07.688] [LOG] Server started …
        [21:04:07.745] [LOG] Sockets connected & modules started …
        –disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
        events.js:174
        throw er; // Unhandled ‘error’ event
        at process. (/home/pi/MagicMirror/js/app.js:40:10)
        And all the modules are loading …
        • C Offline
          cyberphox
          When I try to run npm install after installing this module I get
          npm ERR! zlib: invalid distance too far back
          What the heck?
          • 3 / 3
