    Home Assistant Module
    22 Posts 12 Posters 28.1k Views 18 Watching
      Aaron19953 @skippy_oz
      Any chance this will work with https ?
      I’m receive the same error “Error fetching stats”
      I can see the attributes if I browse to
      https://IP:8123/api/states/sensor.name?api_password=PASSWORD
        skippy_oz
        I have it working with HTTPS :grinning_face:
        Change the url to match what you have for HA
            module: 'MMM-homeassistant-sensors',
            position: 'bottom_right',
                  url: 'https://username.duckdns.org:8123/api/states',
                  prettyName : 'true',
                  stripName: 'true',
                  values: ["sensor.humidity", "sensor.temperature"]
        You will need to modify the node_help.js file for this module change the below line of code /MagicMirror/modules/MMM-homeassistant-sensors/node_helper.js
        request({ url: url, method: 'GET' }, function (error, response, body) {
        To the following and change the api-password to what you have set in HA it’s about line 12.
          request({ url: url, headers: {'x-ha-access': 'api-password'}, method: 'GET' }, function (error, response, body) {
        It’s working it looks like it takes a bit longer to get the data as I think the atentication takes some time.
        Regards
        skippy_oz
