    Restoring the MM boot splash
    13 Posts 5 Posters 3.6k Views 5 Watching
      AxLed Module Developer
      i had the same issue with a clean install of MM on raspian buster.
      For manually setting the MM bootscreen this worked for me:
      cd /usr/share/plymouth/themes/
      sudo mkdir MagicMirror
      sudo cp ~/MagicMirror/splashscreen/splash.png /usr/share/plymouth/themes/MagicMirror/splash.png
      sudo cp ~/MagicMirror/splashscreen/MagicMirror.plymouth /usr/share/plymouth/themes/MagicMirror/MagicMirror.plymouth
      sudo cp ~/MagicMirror/splashscreen/MagicMirror.script /usr/share/plymouth/themes/MagicMirror/MagicMirror.script
      sudo plymouth-set-default-theme -R MagicMirror
      AxLED
        sdetweil @AxLed
        @AxLed that is what the install script does
        • T Offline
          tinwetari
          i dont seem to get this working :(
