    Restoring the MM boot splash
    13 Posts 5 Posters 4.5k Views 5 Watching
      simonbooth @sdetweil
      @sdetweil many thanks!
      I will try this tonight!
      • lavolp3L Offline
        lavolp3 Module Developer
        There is a custom boot splash screen??? :frowning_face_with_open_mouth: :dizzy_face: :smiling_face_with_heart-eyes:
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          sdetweil @lavolp3
          @lavolp3 yes
            sdetweil @lavolp3
            • lavolp3L Offline
              @sdetweil is that only installed with your script? I don’t seem to have it on my mirror with the latest update.
                sdetweil @lavolp3
                @lavolp3 it is/was installed as part of the original install script raspberry.sh, I didn’t change that except to
                add some logging
                # Check if plymouth is installed (default with PIXEL desktop environment), then install custom splashscreen.
                echo -e "\e[96mCheck plymouth installation ...\e[0m" | tee -a $logfile
                if command_exists plymouth; then
                	THEME_DIR="/usr/share/plymouth/themes"
                	echo -e "\e[90mSplashscreen: Checking themes directory.\e[0m" | tee -a $logfile
                	if [ -d $THEME_DIR ]; then
                		echo -e "\e[90mSplashscreen: Create theme directory if not exists.\e[0m" | tee -a $logfile
                		if [ ! -d $THEME_DIR/MagicMirror ]; then
                			sudo mkdir $THEME_DIR/MagicMirror
                		fi
                		if sudo cp ~/MagicMirror/splashscreen/splash.png $THEME_DIR/MagicMirror/splash.png && sudo cp ~/MagicMirror/splashscreen/MagicMirror.plymouth $THEME_DIR/MagicMirror/MagicMirror.plymouth && sudo cp ~/MagicMirror/splashscreen/MagicMirror.script $THEME_DIR/MagicMirror/MagicMirror.script; then
                			echo
                			if [ "$(which plymouth-set-default-theme)." != "." ]; then
                				if sudo plymouth-set-default-theme -R MagicMirror; then
                					echo -e "\e[92mSplashscreen: Changed theme to MagicMirror successfully.\e[0m" | tee -a $logfile
                				else
                					echo -e "\e[91mSplashscreen: Couldn't change theme to MagicMirror!\e[0m" | tee -a $logfile
                				fi
                			fi
                		else
                			echo -e "\e[91mSplashscreen: Copying theme failed!\e[0m" | tee -a $logfile
                		fi
                	else
                		echo -e "\e[91mSplashscreen: Themes folder doesn't exist!\e[0m" | tee -a $logfile
                	fi
                else
                	echo -e "\e[93mplymouth is not installed.\e[0m" | tee -a $logfile
                fi
                • lavolp3L Offline
                  @sdetweil Interesting, so it is currently only present on new installations. Updaters from earlier install don’t get this paticular upgrade.
                  I guess I really need to take some time to look into your script and use it for future updates.
                  Thanks for the explanations!
                    sdetweil @lavolp3
                    @lavolp3 correct. Only installed during initial install.
                    I didn’t create the installer script, only updated it and made it handle more environments.
                    Like the node/npm installs used to be one thing, they are separated now.
                    The old code installed node. And then failed cause npm wasn’t installed.
                    The pm2 install was hard coded to one is platform. I fixed that.
                    It only handled one screensaver config. I fixed that.
                    And added logging.
                    Then I made an upgrade script
                    The upgrade script does what you would do.
                    Download the code, npm install. And then npm install in all the active module folders where there is a package.json file
                      AxLed Module Developer
                      i had the same issue with a clean install of MM on raspian buster.
                      For manually setting the MM bootscreen this worked for me:
                      cd /usr/share/plymouth/themes/
                      sudo mkdir MagicMirror
                      sudo cp ~/MagicMirror/splashscreen/splash.png /usr/share/plymouth/themes/MagicMirror/splash.png
                      sudo cp ~/MagicMirror/splashscreen/MagicMirror.plymouth /usr/share/plymouth/themes/MagicMirror/MagicMirror.plymouth
                      sudo cp ~/MagicMirror/splashscreen/MagicMirror.script /usr/share/plymouth/themes/MagicMirror/MagicMirror.script
                      AxLED
                        sdetweil @AxLed
                        @AxLed that is what the install script does
                        • T Offline
                          tinwetari
                          i dont seem to get this working :(
