    organization of the text next to the icon.
    48 Posts 3 Posters 28.0k Views 5 Watching
    • I
      iorifly
      How to align the left next to the icon?
      If I put the module to the left of the MM, the text is next to the icons.
      But I would like to use the module on the right side,
      https://imgur.com/S8giGqe
        sdetweil @iorifly
        @iorifly i don’t think u can change this with CSS… i would have to see how the author formatted the data… suspect he used a table structure, if so you would have to change the code
        also, it is always nice if u tell us the module that is generating the content
        • I
          iorifly
          boy, you became my tutor on this site !! I just have to thank!
            this is the module.
          https://github.com/leinich/MMM-homeassistant-sensors
          • I
            iorifly
            As I said. If I position the module on the left side. Everything is perfectly aligned.
            If I place the module on the right side, the text is far from the icons.
            Taking advantage of that will look at the code. It is possible, for example, when he displays “off” or “on” he writes in my language …
            I don’t think so, as it pulls that information from the Home Assistant server.
            • I
              iorifly
              I did not find any css files in this addom.
              It would be possible to add lines to separate some functions, or I’m saying stupidity.
                sdetweil @iorifly
                @iorifly
                yes, he creates an html table (table)
                and each row is a table row (tr)
                you would have to move this
                		// Name
                		newCell = newrow.insertCell(1);
                		newText = document.createTextNode(name);
                		newCell.appendChild(newText);
                		// Value
                		newCell = newrow.insertCell(2);
                		newCell.className = "align-right"
                			newText = document.createTextNode(value);
                		// Unit
                		newCell = newrow.insertCell(3);
                		newCell.className = "align-left"
                			newText = document.createTextNode(unit);
                in front of this
                		// icons
                		newCell = newrow.insertCell(0);
                and change the insertCell(?) numbers back to 0-3 in order again
                change 1 to 0,
                2 to 1,
                3 to 2
                and 0 to 3
                as for left/right areas of screen… yes, it is quite a challenge to have the text properly aligned, regardless of the area of the screen (position) selected… there is NO ‘simple’ fix
                • I
                  iorifly
                  I will try to play with this. But already mine gave a north !!!
                     I will try to create the lines. About aligning if standing next to the icons already helps. Now creating html is simpler. I will try to understand. Anything I report.
                  • D
                    doubleT Module Developer
                    Wait! I think that’s not what @iorifly wants, right?
                    If I understand this correct (and it is difficult to understand ;) ) the text in the middle should be aligned left?
                    • I
                      iorifly
                      I will send another photo. with the module positioned to the left of the screen.
                        sdetweil @doubleT
                        @doubleT yes, you are correct… sorry, I misunderstood , I thought he wanted the icons on the right end of the line
                        • I
                          iorifly
                          I actually want it that way. See how the text is perfectly aligned to the icon.
                          https://imgur.com/InsQd3x
                          • I
                            iorifly
                            I also wanted to put lines
                            Like the ones I set as an example. I actually want white line like the one under “Home assistant”
                            https://imgur.com/sx9Muq2
                            • D
                              Ok, I understand. I’m looking at the code and I think it’s not written very good. There are cells named “align-left” and “align-right” – stupid in this case as there’s no CSS for it and the cells are taking their alignment from the module position, it seems.
                              Are you familiar with the dev mode? Can you check the html structure of the table and see if the cells and table rows that you try to change have any class names?
                              I’m trying to figure this out and then I’d suggest some entries in the custom.css file.
                                sdetweil
                                text alignment, you will have to change the code. the author did not provide element classes you could modify with css. (see the code from one of my prior posts, he just set style to ‘align-left’ or ‘align-right’ or let it default (text nodes align right by default for ltr languages)
                                adding a line under some entries,
                                you will have to modify the code to add that capability
                                • D
                                  It can be done in css even if there are no class names. Give me a minute.
                                  • I
                                    iorifly
                                    Thanks! I’m in no hurry. Even because it took me a long time to get here. sdetweil helped me extremely.
                                    Thank you very much for all your support! sensational you !!!.
                                    • D
                                      If you want to work in the code and are not afraid that an update might overwrite it, you could try to change
                                      		// Name
                                      to
                                      		// Name
                                      		newCell.className = "align-left";
                                      That seems to be what’s aligning the icon cell to the left. That css comes from MM’s main.css.
                                      • I
                                        iorifly
                                        I will try to locate this code.
                                        in which module file do I look for it?
                                        • D
                                          MMM-homeassistant-sensors.js
                                          • I
                                            iorifly
                                            @doubleT said in organization of the text next to the icon.:
                                            newCell.className = “align-left”;
                                            alignment resolved. Can I now create lines to separate groups? Or is it impossible?
                                            • 1 / 3
