    organization of the text next to the icon.
    48 Posts 3 Posters 22.5k Views 5 Watching
    • I Offline
      iorifly
      How to align the left next to the icon?
      If I put the module to the left of the MM, the text is next to the icons.
      But I would like to use the module on the right side,
      https://imgur.com/S8giGqe
        sdetweil @iorifly
        @iorifly i don’t think u can change this with CSS… i would have to see how the author formatted the data… suspect he used a table structure, if so you would have to change the code
        also, it is always nice if u tell us the module that is generating the content
        • I Offline
          iorifly
          boy, you became my tutor on this site !! I just have to thank!
          this is the module.
          https://github.com/leinich/MMM-homeassistant-sensors
          • I Offline
            iorifly
            As I said. If I position the module on the left side. Everything is perfectly aligned.
            If I place the module on the right side, the text is far from the icons.
            Taking advantage of that will look at the code. It is possible, for example, when he displays “off” or “on” he writes in my language …
            I don’t think so, as it pulls that information from the Home Assistant server.
            • I Offline
              iorifly
              I did not find any css files in this addom.
              It would be possible to add lines to separate some functions, or I’m saying stupidity.
                sdetweil @iorifly
                @iorifly
                yes, he creates an html table (table)
                and each row is a table row (tr)
                you would have to move this
                		// Name
                		newCell = newrow.insertCell(1);
                		newText = document.createTextNode(name);
                		newCell.appendChild(newText);
                		// Value
                		newCell = newrow.insertCell(2);
                		newCell.className = "align-right"
                			newText = document.createTextNode(value);
                		// Unit
                		newCell = newrow.insertCell(3);
                		newCell.className = "align-left"
                			newText = document.createTextNode(unit);
                in front of this
                		// icons
                		newCell = newrow.insertCell(0);
                and change the insertCell(?) numbers back to 0-3 in order again
                change 1 to 0,
                2 to 1,
                3 to 2
                and 0 to 3
                as for left/right areas of screen… yes, it is quite a challenge to have the text properly aligned, regardless of the area of the screen (position) selected… there is NO ‘simple’ fix
                • I Offline
                  iorifly
                  I will try to play with this. But already mine gave a north !!!
                  I will try to create the lines. About aligning if standing next to the icons already helps. Now creating html is simpler. I will try to understand. Anything I report.
                    doubleT Module Developer
                    Wait! I think that’s not what @iorifly wants, right?
                    If I understand this correct (and it is difficult to understand ;) ) the text in the middle should be aligned left?
                    • I Offline
                      iorifly
                      I will send another photo. with the module positioned to the left of the screen.
                        sdetweil @doubleT
                        @doubleT yes, you are correct… sorry, I misunderstood , I thought he wanted the icons on the right end of the line
                        • 1 / 5
