    Touch input examples for MM Module
    18 Posts 5 Posters 4.5k Views 5 Watching
      sdetweil @jcleary05
      @jcleary05 also see https://forum.magicmirror.builders/topic/8734/mmm-mysqlquery-module-just-released
      for connection and query…
        jcleary05
        Also guys, when creating the initial content of the module, will it have to be built using the document objet model or will I be able to bring in a HTML page and edit it using the DOM? Unsure of where to kick of from
        you can use the element.innerHTML value to inject a raw html text block into that element
          sdetweil @jcleary05
          @jcleary05 the module is contributing a small section of html, ONLY its content… the overall page is managed by MM…
          the getDom() method returns the small dom tree to inject into the page… in the position element of the page…
          see my sample module https://github.com/sdetweil/SampleModule
          if u look at ~/MagicMirror/index.html, you will see the page layout
          each module is placed into one of those regions.
          if you use the developers window (ctrl-shift-i) and select the elements tab. you can see the modules output in place
            delrein
            This post is deleted!
              jcleary05
              Thanks for all your help so far!
              I am currently trying to build a step by step form, which the user will interact with to answer a number of questions.
              Would it be possible to run each element of this form as separate functions called by the getDom function?
              Also, to make things easier, would it be possible to call in a piece of html into the js file to work with, instead of having to build the entire form using the createElement functions?
              The example I am currently trying to build is similar to this:
              https://www.w3schools.com/howto/howto_js_form_steps.asp
                sdetweil @jcleary05
                @jcleary05 sure, u can add a text html string into the innerHTML of an element like a div
                  sdetweil @jcleary05
                  @jcleary05 run each button press as separate. Sure.
                  They don’t have to be online in getDom(). They just have to be linked to the button onClick
                    dvbit
                    Some future direction and option
                    https://github.com/dvbit/Kinect-Mouse-Swipe-C-Module
                    Not touch but gestures
