    Touch input examples for MM Module
    18 Posts 5 Posters 5.6k Views 5 Watching
      sdetweil @jcleary05
      @jcleary05 sure… I use mongodb, and connect to it via the node helper
      here is a web page that describes all the operations (connect, search/get/select,
      update,
      https://www.w3schools.com/nodejs/nodejs_mysql.asp
        jcleary05 @lavolp3
        @lavolp3 Sorry man just seeing your message now,
        Thank you! this will be extremely helpful!
        S 2 Replies Last reply
          sdetweil @jcleary05
          @jcleary05 sorry, forgot to paste in the url
            jcleary05 @lavolp3
            @lavolp3
            Just reviewing your modules, they look great! in particular I may have a use case for the keyboard, do you have an estimation when it will be ready to use?
              sdetweil @jcleary05
              @jcleary05 also see https://forum.magicmirror.builders/topic/8734/mmm-mysqlquery-module-just-released
              for connection and query…
                jcleary05
                Also guys, when creating the initial content of the module, will it have to be built using the document objet model or will I be able to bring in a HTML page and edit it using the DOM? Unsure of where to kick of from
                you can use the element.innerHTML value to inject a raw html text block into that element
                  sdetweil @jcleary05
                  @jcleary05 the module is contributing a small section of html, ONLY its content… the overall page is managed by MM…
                  the getDom() method returns the small dom tree to inject into the page… in the position element of the page…
                  see my sample module https://github.com/sdetweil/SampleModule
                  if u look at ~/MagicMirror/index.html, you will see the page layout
                  each module is placed into one of those regions.
                  if you use the developers window (ctrl-shift-i) and select the elements tab. you can see the modules output in place
                    delrein
                      jcleary05
                      Thanks for all your help so far!
                      I am currently trying to build a step by step form, which the user will interact with to answer a number of questions.
                      Would it be possible to run each element of this form as separate functions called by the getDom function?
                      Also, to make things easier, would it be possible to call in a piece of html into the js file to work with, instead of having to build the entire form using the createElement functions?
                      The example I am currently trying to build is similar to this:
                      https://www.w3schools.com/howto/howto_js_form_steps.asp
                        sdetweil @jcleary05
                        @jcleary05 sure, u can add a text html string into the innerHTML of an element like a div
                          sdetweil @jcleary05
                          @jcleary05 run each button press as separate. Sure.
                          They don’t have to be online in getDom(). They just have to be linked to the button onClick
                            dvbit
                            Some future direction and option
                            https://github.com/dvbit/Kinect-Mouse-Swipe-C-Module
                            Not touch but gestures
