    Touch input examples for MM Module
    18 Posts 5 Posters 5.6k Views 5 Watching
    • lavolp3L
      lavolp3 Module Developer @jcleary05
      @jcleary05 For touch input, have a look at these:
      https://github.com/werthdavid/MMM-Bring
      https://github.com/lavolp3/MMM-Keyboard (not ready yet, but soon!)
      https://github.com/lavolp3/MMM-NavigationBar
      As you see I’m working extensively on a “touch MM” as a kitchen hub.
      Regarding a database, I can’t help you
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      J 2 Replies Last reply
        jcleary05
        @sdetweil Thanks for getting back to me!
        The database will most likely be based of mySQL using phpMyAdmin (The university provides this)
        Im unsure how I would actually gain access to this database and submit to it using the current setup of modules. Could this potentially be done using node js?
          sdetweil @jcleary05
          @jcleary05 mysql, yes , see the node library https://www.npmjs.com/package/mysql, which gives you node methods to call to connect and access the database
            jcleary05
            Thanks again for getting back to me!
            Do you believe it will be possible for me to submit an entry to a database using the nodehelper.js file?
            I am currently trying to find an example but I am unsure of any which are available?
              sdetweil @jcleary05
              @jcleary05 sure… I use mongodb, and connect to it via the node helper
              here is a web page that describes all the operations (connect, search/get/select,
              update,
              https://www.w3schools.com/nodejs/nodejs_mysql.asp
                jcleary05 @lavolp3
                @lavolp3 Sorry man just seeing your message now,
                Thank you! this will be extremely helpful!
                S 2 Replies Last reply
                  sdetweil @jcleary05
                  @jcleary05 sorry, forgot to paste in the url
                    jcleary05 @lavolp3
                    @lavolp3
                    Just reviewing your modules, they look great! in particular I may have a use case for the keyboard, do you have an estimation when it will be ready to use?
                      sdetweil @jcleary05
                      @jcleary05 also see https://forum.magicmirror.builders/topic/8734/mmm-mysqlquery-module-just-released
                      for connection and query…
                        jcleary05
                        Also guys, when creating the initial content of the module, will it have to be built using the document objet model or will I be able to bring in a HTML page and edit it using the DOM? Unsure of where to kick of from
                        you can use the element.innerHTML value to inject a raw html text block into that element
                          sdetweil @jcleary05
                          @jcleary05 the module is contributing a small section of html, ONLY its content… the overall page is managed by MM…
                          the getDom() method returns the small dom tree to inject into the page… in the position element of the page…
                          see my sample module https://github.com/sdetweil/SampleModule
                          if u look at ~/MagicMirror/index.html, you will see the page layout
                          each module is placed into one of those regions.
                          if you use the developers window (ctrl-shift-i) and select the elements tab. you can see the modules output in place
                            delrein
                              jcleary05
                              Thanks for all your help so far!
                              I am currently trying to build a step by step form, which the user will interact with to answer a number of questions.
                              Would it be possible to run each element of this form as separate functions called by the getDom function?
                              Also, to make things easier, would it be possible to call in a piece of html into the js file to work with, instead of having to build the entire form using the createElement functions?
                              The example I am currently trying to build is similar to this:
                              https://www.w3schools.com/howto/howto_js_form_steps.asp
                                sdetweil @jcleary05
                                @jcleary05 sure, u can add a text html string into the innerHTML of an element like a div
                                  sdetweil @jcleary05
                                  @jcleary05 run each button press as separate. Sure.
                                  They don’t have to be online in getDom(). They just have to be linked to the button onClick
                                    dvbit
                                    Some future direction and option
                                    https://github.com/dvbit/Kinect-Mouse-Swipe-C-Module
                                    Not touch but gestures
