    Touch input examples for MM Module
    18 Posts 5 Posters 4.1k Views 5 Watching
      jcleary05
      Hi Guys
      I am currently in the process of building a module for my dissertation project in university. The module which I will be building will require touch input to complete a questionaire and push the answers of the questionaire to a database.
      Could anyone point me towards some modules which utilise touch input and/or push information to a database?
      S lavolp3L 2 Replies Last reply Reply Quote 0
        sdetweil @jcleary05
        @jcleary05 so, first you have to put MM on a system with a touch screen…
        after than your module would create a small html ‘page’ with a normal html form in it,
        and use the exact same techniques as any javascript driven page…
        you add am event Handler to the button on the form, and then use the document. xxx methods to extract the field data
        https://stackoverflow.com/questions/11563638/how-do-i-get-the-value-of-text-input-field-using-javascript
        push info to database… what database? in Mongodb adding a record looks like
        db.collection(collection_name).insertOne(jsondata, function(err,result){ })
        • lavolp3L Offline
          lavolp3 Module Developer @jcleary05
          @jcleary05 For touch input, have a look at these:
          https://github.com/werthdavid/MMM-Bring
          https://github.com/lavolp3/MMM-Keyboard (not ready yet, but soon!)
          https://github.com/lavolp3/MMM-NavigationBar
          As you see I’m working extensively on a “touch MM” as a kitchen hub.
          Regarding a database, I can’t help you
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          J 2 Replies Last reply Reply Quote 1
            jcleary05
            @sdetweil Thanks for getting back to me!
            The database will most likely be based of mySQL using phpMyAdmin (The university provides this)
            Im unsure how I would actually gain access to this database and submit to it using the current setup of modules. Could this potentially be done using node js?
              sdetweil @jcleary05
              @jcleary05 mysql, yes , see the node library https://www.npmjs.com/package/mysql, which gives you node methods to call to connect and access the database
                jcleary05
                Thanks again for getting back to me!
                Do you believe it will be possible for me to submit an entry to a database using the nodehelper.js file?
                I am currently trying to find an example but I am unsure of any which are available?
                  sdetweil @jcleary05
                  @jcleary05 sure… I use mongodb, and connect to it via the node helper
                  here is a web page that describes all the operations (connect, search/get/select,
                  update,
                  https://www.w3schools.com/nodejs/nodejs_mysql.asp
                    jcleary05 @lavolp3
                    @lavolp3 Sorry man just seeing your message now,
                    Thank you! this will be extremely helpful!
                      sdetweil @jcleary05
                      @jcleary05 sorry, forgot to paste in the url
                        jcleary05 @lavolp3
                        @lavolp3
                        Just reviewing your modules, they look great! in particular I may have a use case for the keyboard, do you have an estimation when it will be ready to use?
