    Touch input examples for MM Module
    18 Posts 5 Posters 4.6k Views 5 Watching
      jcleary05
      Thanks again for getting back to me!
      Do you believe it will be possible for me to submit an entry to a database using the nodehelper.js file?
      I am currently trying to find an example but I am unsure of any which are available?
        sdetweil @jcleary05
        @jcleary05 sure… I use mongodb, and connect to it via the node helper
        here is a web page that describes all the operations (connect, search/get/select,
        update,
        https://www.w3schools.com/nodejs/nodejs_mysql.asp
          jcleary05 @lavolp3
          @lavolp3 Sorry man just seeing your message now,
          Thank you! this will be extremely helpful!
            sdetweil @jcleary05
            @jcleary05 sorry, forgot to paste in the url
              jcleary05 @lavolp3
              @lavolp3
              Just reviewing your modules, they look great! in particular I may have a use case for the keyboard, do you have an estimation when it will be ready to use?
                sdetweil @jcleary05
                @jcleary05 also see https://forum.magicmirror.builders/topic/8734/mmm-mysqlquery-module-just-released
                for connection and query…
                  jcleary05
                  Also guys, when creating the initial content of the module, will it have to be built using the document objet model or will I be able to bring in a HTML page and edit it using the DOM? Unsure of where to kick of from
                  you can use the element.innerHTML value to inject a raw html text block into that element
                    sdetweil @jcleary05
                    @jcleary05 the module is contributing a small section of html, ONLY its content… the overall page is managed by MM…
                    the getDom() method returns the small dom tree to inject into the page… in the position element of the page…
                    see my sample module https://github.com/sdetweil/SampleModule
                    if u look at ~/MagicMirror/index.html, you will see the page layout
                    each module is placed into one of those regions.
                    if you use the developers window (ctrl-shift-i) and select the elements tab. you can see the modules output in place
                      delrein
                        jcleary05
                        Thanks for all your help so far!
                        I am currently trying to build a step by step form, which the user will interact with to answer a number of questions.
                        Would it be possible to run each element of this form as separate functions called by the getDom function?
                        Also, to make things easier, would it be possible to call in a piece of html into the js file to work with, instead of having to build the entire form using the createElement functions?
                        The example I am currently trying to build is similar to this:
                        https://www.w3schools.com/howto/howto_js_form_steps.asp
