    MMM-AssistantMk2 with Google AIY
    16 Posts 4 Posters 4.2k Views 4 Watching
    • ? Offline
      A Former User
      ok , i wait
      give me all log plz
      and give me your config.js file
      • N Offline
        nakedrabbit
        logs from pm2:
        0|mm | [AMK2] MMM-AssistantMk2 Version: 3.1.0-3
        0|mm | [AMK2] AssistantMk2 is initialized.
        0|mm | [HOTWORD] begins.
        0|mm | [HOTWORD] Detector starts listening.
        0|mm | [HOTWORD] Detected: SMARTMIRROR
        0|mm | [HOTWORD] After Recording: 4000
        0|mm | [HOTWORD] stops.
        0|mm | [HOTWORD] After Recording finised. size: 16050
        0|mm | [HOTWORD:B2W] WAV_FILE_CREATED: /home/pi/MagicMirror/modules/MMM-Hotword/temp/afterRecording.wav 16050
        0|mm | [HOTWORD] Final Result: { detected: true,
        0|mm | hotword: ‘SMARTMIRROR’,
        0|mm | file: ‘temp/afterRecording.wav’ }
        It is true, Hotword records a 16K file that seems to only include noise. It does recognize and pass me to AssistantMk2, but immediately says “I don’t understand” and then cannot be invoked again.
        The file “temp/afterRecording.wav” exists, but it is a 0K file.
        Config for MM sections are here:
        module: “MMM-AssistantMk2”,
        position: “top_left”,
        assistantConfig: {
        latitude: 51.508530,
        longitude: -0.076132,
        playProgram: “mpg321”,
        responseConfig: {
        useHTML5: false,
        micConfig: { // put there configuration generated by auto-installer
        recorder: “arecord”,
        device: “plughw:0”,
        module: “MMM-Hotword”,
        position: “bottom_left”,
        useDisplay: false,
        chimeOnFinish: null,
        recipes: [“with-AMk2v3_smart-mirror.js”],
        mic: {
        recordProgram: “arecord”,
        device: “plughw:0”,
        Forum does not allow uploading the .js file, if you need the whole thing lemme know and I’ll put it up somewhere else.
        • ? Offline
          A Former User
            module: "MMM-Hotword",
            position: "bottom_left",
              useDisplay: false,
              recipes: ["with-AMk2v3-noisy_smart-mirror.js"],
              mic: {
                recordProgram: "arecord",
                device: "plughw:0",
          can you retry with this MMM-Hotword configuration ?
          edit 1: sorry, correct mismake
          edit 2:
          humm there is some mismake in your AMk2 config
          i propose this AMk2 config :
            module: "MMM-AssistantMk2",
              debug: true,
              ui: "Fullscreen",
              assistantConfig: {
              responseConfig: {
                useHTML5: false,
                playProgram: "mpg321",
                useStaticIcons: false,
              micConfig: {
                recorder: "arecord",
                device: "plughw:0",
              recipes: [ "with-MMM-Hotword.js" ]
              profiles: {
               "default": {
                  profileFile: "default.json",
                  lang: "en-US"
              addons: false,
            sdetweil @nakedrabbit
            @nakedrabbit please use the code marker for all config entry data u might post…
            paste the text,
            then mark it, and hit the </> button above the edit box
            • N Offline
              nakedrabbit @Guest
              @Bugsounet YOU ARE A MAGIC MAN.
              And @sdetweil , you are quite right about my forum incompetence. For the record I will try to do better right now.
              Bugs, there were some commas missing that threw me off for a while, but this is the config that worked/ I encourage @Croeder to check this out, since I am also using the Google Hat.
                  			debug: true,
                  			ui: "Fullscreen",
                  			assistantConfig: {
                  			responseConfig: {
                    				useHTML5: false,
                  			micConfig: {
                    				device: "plughw:0",
                  			recipes: [ "with-MMM-Hotword.js" ],
                  			profiles: {
                   				"default": {
                      				lang: "en-US",
                  			addons: false,
              • ? Offline
                A Former User
                I think, it’s works now :)
                • Your default location is defined by this block:
                    assistantConfig: {
                change latitude and longitude value for your actual position
                This website can help you to determinate it
                • For language change:
                change the value lang: "en-US", (actually in english) in
                  profiles: {
                    "default": {
                      lang: "en-US",
                Change the lang value by your own.
                You can determinate it there
                Notes:
                • I’m not a magician, just a hobbyist programmer of this module ;)
                • Read wiki for advanced config
