    MMM-AssistantMk2 with Google AIY
    16 Posts 4 Posters 5.1k Views 4 Watching
    • N Offline
      nakedrabbit @Guest
      @Bugsounet Sorry I was away for a bit.
      YES! I’m ready to try anything, including burning it all down and starting over. Let me know what I can do!
      My issues do not SEEM to be mic or speaker configs. When I install the tests all work just great. I do seem to have memory issues.
      Give me the tests! And thank you!
        A Former User
        So go on :)
        Generally memory problems are due to the use of sound via HTML5 (we don’t know really why)
        Let’s turn off and use the “native” sound of rpi
        in your config.js MMM-AssistantMk2
        let’s turn off HTML5 sound by using useHTML5: false
        if this feature don’t exist in your config
        wiki can help you to find needed block to add it
        Of course, you will have to restart MagicMiror after this modification
        awaiting your first return
        N 2 Replies Last reply Reply Quote 0
        • N Offline
          nakedrabbit @Guest
          @Bugsounet said in MMM-AssistantMk2 with Google AIY:
          useHTML5: false
          I’ve had that one in my config all along, so yes, I’ve accomplished this first step a while ago, still have the problem.
          • N Offline
            nakedrabbit @Guest
            @Bugsounet NO WAIT!
            I did not configure properly! I did not realize the HTML5 option needed to be enclosed in the responseConfig section. Thanks for linking the wiki so I could double-check!
            No response yet. This is AssistantMk2 with your own snowboy option selected and Hotword NOT enabled. I’m going to try Hotword again now.
              A Former User
              ok , i wait
              give me all log plz
              and give me your config.js file
              • N Offline
                nakedrabbit
                logs from pm2:
                0|mm | [AMK2] MMM-AssistantMk2 Version: 3.1.0-3
                0|mm | [AMK2] AssistantMk2 is initialized.
                0|mm | [HOTWORD] begins.
                0|mm | [HOTWORD] Detector starts listening.
                0|mm | [HOTWORD] Detected: SMARTMIRROR
                0|mm | [HOTWORD] After Recording: 4000
                0|mm | [HOTWORD] stops.
                0|mm | [HOTWORD] After Recording finised. size: 16050
                0|mm | [HOTWORD:B2W] WAV_FILE_CREATED: /home/pi/MagicMirror/modules/MMM-Hotword/temp/afterRecording.wav 16050
                0|mm | [HOTWORD] Final Result: { detected: true,
                0|mm | hotword: ‘SMARTMIRROR’,
                0|mm | file: ‘temp/afterRecording.wav’ }
                It is true, Hotword records a 16K file that seems to only include noise. It does recognize and pass me to AssistantMk2, but immediately says “I don’t understand” and then cannot be invoked again.
                The file “temp/afterRecording.wav” exists, but it is a 0K file.
                Config for MM sections are here:
                module: “MMM-AssistantMk2”,
                position: “top_left”,
                assistantConfig: {
                latitude: 51.508530,
                longitude: -0.076132,
                playProgram: “mpg321”,
                responseConfig: {
                useHTML5: false,
                micConfig: { // put there configuration generated by auto-installer
                recorder: “arecord”,
                device: “plughw:0”,
                module: “MMM-Hotword”,
                position: “bottom_left”,
                useDisplay: false,
                chimeOnFinish: null,
                recipes: [“with-AMk2v3_smart-mirror.js”],
                mic: {
                recordProgram: “arecord”,
                device: “plughw:0”,
                Forum does not allow uploading the .js file, if you need the whole thing lemme know and I’ll put it up somewhere else.
                  A Former User
                    module: "MMM-Hotword",
                    position: "bottom_left",
                      useDisplay: false,
                      recipes: ["with-AMk2v3-noisy_smart-mirror.js"],
                      mic: {
                        recordProgram: "arecord",
                        device: "plughw:0",
                  can you retry with this MMM-Hotword configuration ?
                  edit 1: sorry, correct mismake
                  edit 2:
                  humm there is some mismake in your AMk2 config
                  i propose this AMk2 config :
                    module: "MMM-AssistantMk2",
                      debug: true,
                      ui: "Fullscreen",
                      assistantConfig: {
                      responseConfig: {
                        useHTML5: false,
                        playProgram: "mpg321",
                        useStaticIcons: false,
                      micConfig: {
                        recorder: "arecord",
                        device: "plughw:0",
                      recipes: [ "with-MMM-Hotword.js" ]
                      profiles: {
                       "default": {
                          profileFile: "default.json",
                          lang: "en-US"
                      addons: false,
                    sdetweil @nakedrabbit
                    @nakedrabbit please use the code marker for all config entry data u might post…
                    paste the text,
                    then mark it, and hit the </> button above the edit box
                    • N Offline
                      nakedrabbit @Guest
                      @Bugsounet YOU ARE A MAGIC MAN.
                      And @sdetweil , you are quite right about my forum incompetence. For the record I will try to do better right now.
                      Bugs, there were some commas missing that threw me off for a while, but this is the config that worked/ I encourage @Croeder to check this out, since I am also using the Google Hat.
                          			debug: true,
                          			ui: "Fullscreen",
                          			assistantConfig: {
                          			responseConfig: {
                            				useHTML5: false,
                          			micConfig: {
                            				device: "plughw:0",
                          			recipes: [ "with-MMM-Hotword.js" ],
                          			profiles: {
                           				"default": {
                              				lang: "en-US",
                          			addons: false,
                        A Former User
                        I think, it’s works now :)
                        • Your default location is defined by this block:
                            assistantConfig: {
                        change latitude and longitude value for your actual position
                        This website can help you to determinate it
                        • For language change:
                        change the value lang: "en-US", (actually in english) in
                          profiles: {
                            "default": {
                              lang: "en-US",
                        Change the lang value by your own.
                        You can determinate it there
                        Notes:
                        • I’m not a magician, just a hobbyist programmer of this module ;)
                        • Read wiki for advanced config
