    MMM-AssistantMk2 with Google AIY
    16 Posts 4 Posters 3.9k Views 4 Watching
    • N Offline
      nakedrabbit @Croeder
      @Croeder Howdy!
      I’m also working with the Google AIY kit, so I have a little experience to share. First, version 2 of the AssistantMk2 module does not, repeat not, work with the Google Hat. Not at all. A couple of us have found that out, and even the developer suggests that there is something wacky about Google’s use of the ALSA drivers or somesuch.
      The reason the moduel may not be showing up could be with having to rebuild electron, which is a documented bug for v2.
      I can report that v3 of the module will install on the Google Hat just fine, and will give you all the feedback and test results you want… BUT… right now there seems to be a memory issue with the module and they are still working on it. You can see my part of the discussion here:
      https://forum.magicmirror.builders/topic/11991/mmm-assistantmk2-v3/39
      I have also tried installing the Google AIY assistant as a service, loading on startup. The advantage there is you get your LED button back. But I had issues with the responses cutting off and being weird, so I deinstalled that.
      Just waiting for results on version 3 now…!
        A Former User
        hi,
        do you want to try to configure it with Google AIY ?
        i think, it should be possible ;)
        we can try if you want !
        @bugsounet (MMM-AssistantMk2 developer)
          Croeder @nakedrabbit
          @nakedrabbit
          I appreciate the reply!
          I might be mistaken but I believe that I was running v3 of the module. Odd that it works for you but not for me. May be something with the hardware. I’m sure I’ll figure it out eventually though :thumbs_up:
            Croeder @Guest
            @Bugsounet
            Hey! Sorry for the late response. I’d love to try to configure it if you are still down!
              A Former User
              so, what is the problem at now ?
              memory issue ?
              playback issue ?
              configuring problem to find mic config ?
              for memory issue, i have some solutions …
              if it’s for AMK2 memory, i have solution
              if memory low is with MMM-Hotword, i have again a solution :)
              there many things to test :)
              Ready ?
              • N Offline
                nakedrabbit @Guest
                @Bugsounet Sorry I was away for a bit.
                YES! I’m ready to try anything, including burning it all down and starting over. Let me know what I can do!
                My issues do not SEEM to be mic or speaker configs. When I install the tests all work just great. I do seem to have memory issues.
                Give me the tests! And thank you!
                  A Former User
                  So go on :)
                  Generally memory problems are due to the use of sound via HTML5 (we don’t know really why)
                  Let’s turn off and use the “native” sound of rpi
                  in your config.js MMM-AssistantMk2
                  let’s turn off HTML5 sound by using useHTML5: false
                  if this feature don’t exist in your config
                  wiki can help you to find needed block to add it
                  Of course, you will have to restart MagicMiror after this modification
                  awaiting your first return
                  N 2 Replies Last reply Reply Quote 0
                  • N Offline
                    nakedrabbit @Guest
                    @Bugsounet said in MMM-AssistantMk2 with Google AIY:
                    useHTML5: false
                    I’ve had that one in my config all along, so yes, I’ve accomplished this first step a while ago, still have the problem.
                    • N Offline
                      nakedrabbit @Guest
                      @Bugsounet NO WAIT!
                      I did not configure properly! I did not realize the HTML5 option needed to be enclosed in the responseConfig section. Thanks for linking the wiki so I could double-check!
                      No response yet. This is AssistantMk2 with your own snowboy option selected and Hotword NOT enabled. I’m going to try Hotword again now.
                        A Former User
                        ok , i wait
                        give me all log plz
                        and give me your config.js file
