    PI Zero module issues for this beginner
    24 Posts 2 Posters 8.4k Views 2 Watching
    • W Offline
      wagon40
      can you send me the direct script to place in the command line to load your script? I have tried a few bash $( bala bal bal) and im not getting much luck.
      I tried to follow this https://forum.magicmirror.builders/topic/9386/installing-on-a-pi-zero/72
      but of course it wont start. screen goes to sleep and it only starts for a minute then goes to desktop.
      I installed buster with desktop.
        sdetweil @wagon40
        @wagon40 from the page I referenced
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
        you can do that over ssh, or on the pi monitor terminal session
        it will prompt you about autostart with pm2 and turning off screensaver
        • W Offline
          wagon40 @sdetweil
          all was going well until the dependencies stopped it. tired to send the code using </> or :: but it blanks out the submit button?
          • W Offline
            wagon40 @wagon40
            @wagon40
            npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
            npm ERR!     /home/pi/.npm/_logs/2020-02-05T21_24_22_985Z-debug.log
              sdetweil @wagon40
              @wagon40 hm… I don’t see that on my pi 0…
              And electron is optional, so there should be no need for chrome driver
              • W Offline
                wagon40
                Same issue I had with the other download. any suggestion?
                npm ERR! errno 1
                npm ERR!
                npm ERR!     /home/pi/.npm/_logs/2020-02-05T22_31_04_266Z-debug.log
                  sdetweil @wagon40
                  @wagon40 I will have to look. It will be a couple hours. Have grandson now
                  • W Offline
                    wagon40
                    Tried to npm start and it states that i dont have a config.js. went to the desktop and i can navigate to the magicmirror file and open the config sample. not sure why it isnt loading? did a reboot and it is not starting MM.
                      sdetweil @wagon40
                      @wagon40 because the install didn’t finish… copy config.js.sample to config.js
                      can u show me the ~/install.log?
                      other things might fail too… as it didn’t complete the install steps…
                      i am trying again right now on my pi 0, but on jessie (as thats the OS level I have installed there at the moment)
                      • W Offline
                        wagon40
                        nothing for install.log. tried a few different ways. I was able to make a copy but just a black screen on npm start up. not sure what to do.
                        • 3 / 3
