    PI Zero module issues for this beginner
    24 Posts 2 Posters 9.7k Views 2 Watching
    • W Offline
      wagon40 @sdetweil
      @sdetweil thank you for the quick reply. I will try your download tomorrow if I get a chance and hopefully have better luck.
        sdetweil @wagon40
        @wagon40 to install MM again, you will need to rename the current folder out of the way
        do this
        cd ~
        mv MagicMirror  MagicMirror.save
        • W Offline
          wagon40
          can you send me the direct script to place in the command line to load your script? I have tried a few bash $( bala bal bal) and im not getting much luck.
          I tried to follow this https://forum.magicmirror.builders/topic/9386/installing-on-a-pi-zero/72
          but of course it wont start. screen goes to sleep and it only starts for a minute then goes to desktop.
          I installed buster with desktop.
            sdetweil @wagon40
            @wagon40 from the page I referenced
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
            you can do that over ssh, or on the pi monitor terminal session
            it will prompt you about autostart with pm2 and turning off screensaver
            • W Offline
              wagon40 @sdetweil
              all was going well until the dependencies stopped it. tired to send the code using </> or :: but it blanks out the submit button?
              • W Offline
                wagon40 @wagon40
                @wagon40
                npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                npm ERR!     /home/pi/.npm/_logs/2020-02-05T21_24_22_985Z-debug.log
                Unable to install dependencies!
                  sdetweil @wagon40
                  @wagon40 hm… I don’t see that on my pi 0…
                  And electron is optional, so there should be no need for chrome driver
                  • W Offline
                    wagon40
                    Same issue I had with the other download. any suggestion?
                    npm ERR! errno 1
                    npm ERR!
                    npm ERR!     /home/pi/.npm/_logs/2020-02-05T22_31_04_266Z-debug.log
                      sdetweil @wagon40
                      @wagon40 I will have to look. It will be a couple hours. Have grandson now
                      • W Offline
                        wagon40
                        Tried to npm start and it states that i dont have a config.js. went to the desktop and i can navigate to the magicmirror file and open the config sample. not sure why it isnt loading? did a reboot and it is not starting MM.
                          sdetweil @wagon40
                          @wagon40 because the install didn’t finish… copy config.js.sample to config.js
                          can u show me the ~/install.log?
                          other things might fail too… as it didn’t complete the install steps…
                          i am trying again right now on my pi 0, but on jessie (as thats the OS level I have installed there at the moment)
                          • W Offline
                            wagon40
                            nothing for install.log. tried a few different ways. I was able to make a copy but just a black screen on npm start up. not sure what to do.
                            • W Offline
                              wagon40
                              I ran this command and got that
                              npm run config:check
                              npm ERR! code ENOENT
                              npm ERR! syscall open
                              npm ERR! errno -2
                              npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                              npm ERR! enoent This is related to npm not being able to find a file.
                              npm ERR! enoent
                              npm ERR!     /home/pi/.npm/_logs/2020-02-06T00_34_33_299Z-debug.log
                                sdetweil @wagon40
                                @wagon40 did u run my script? it creates a log file…
                                gotta be IN the MagicMirror folder
                                to get the base config
                                cd ~/MagicMirror/config
                                cp config.js.sample config.js
                                but the system is a mess right now… hang on I am testing a fixed installer…
                                • W Offline
                                  wagon40
                                  I appreciate your help and putting up with a noob
                                  pi@raspberrypi:~/MagicMirror/config $ npm run config:check
                                  > magicmirror@2.10.1 config:check /home/pi/MagicMirror
                                  > node tests/configs/check_config.js
                                  Checking file...  /home/pi/MagicMirror/config/config.js
                                  Your configuration file doesn't contain syntax errors :)
                                    erase the current MagicMirror folder (rm -rf MagicMirror )
                                    and run the install script again , they changed some upstream library to hard fail…
                                    but we didn’t need it anyhow…
                                      sdetweil @wagon40
                                      @wagon40 said in PI Zero module issues for this beginner:
                                      we were all noobs once…
                                        @sdetweil my test of installer on buster on pi 0, comes up running fine now
                                        • W Offline
                                          wagon40
                                          was able to get it to work. only issues is screensaver continues to active.
                                          tried this with no luck
                                          sudo nano /etc/xdg/lxsession/LXDE/autostart
                                          add the following lines:
                                          @xset s noblank
                                          @xset s off
                                          @xset -dpms
                                          Save and close, using the commands CTRL-O and CTRL-X.
                                          Go to lightdm.conf:
                                          sudo nano /etc/lightdm/lightdm.conf
                                          xserver-command=X -s 0 -dpms
                                            sdetweil @wagon40
                                            @wagon40 I noticed that too.
                                            Do this
                                            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)"
