    PI Zero module issues for this beginner
    24 Posts 2 Posters 10.2k Views 2 Watching
      sdetweil @wagon40
      @wagon40 I will have to look. It will be a couple hours. Have grandson now
      • W Offline
        wagon40
        Tried to npm start and it states that i dont have a config.js. went to the desktop and i can navigate to the magicmirror file and open the config sample. not sure why it isnt loading? did a reboot and it is not starting MM.
          sdetweil @wagon40
          @wagon40 because the install didn’t finish… copy config.js.sample to config.js
          can u show me the ~/install.log?
          other things might fail too… as it didn’t complete the install steps…
          i am trying again right now on my pi 0, but on jessie (as thats the OS level I have installed there at the moment)
          • W Offline
            wagon40
            nothing for install.log. tried a few different ways. I was able to make a copy but just a black screen on npm start up. not sure what to do.
            • W Offline
              wagon40
              I ran this command and got that
              npm run config:check
              npm ERR! code ENOENT
              npm ERR! syscall open
              npm ERR! errno -2
              npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
              npm ERR! enoent This is related to npm not being able to find a file.
              npm ERR! enoent
              npm ERR!     /home/pi/.npm/_logs/2020-02-06T00_34_33_299Z-debug.log
                sdetweil @wagon40
                @wagon40 did u run my script? it creates a log file…
                gotta be IN the MagicMirror folder
                to get the base config
                cd ~/MagicMirror/config
                cp config.js.sample config.js
                but the system is a mess right now… hang on I am testing a fixed installer…
                • W Offline
                  wagon40
                  I appreciate your help and putting up with a noob
                  pi@raspberrypi:~/MagicMirror/config $ npm run config:check
                  > magicmirror@2.10.1 config:check /home/pi/MagicMirror
                  > node tests/configs/check_config.js
                  Checking file...  /home/pi/MagicMirror/config/config.js
                  Your configuration file doesn't contain syntax errors :)
                    erase the current MagicMirror folder (rm -rf MagicMirror )
                    and run the install script again , they changed some upstream library to hard fail…
                    but we didn’t need it anyhow…
                      sdetweil @wagon40
                      @wagon40 said in PI Zero module issues for this beginner:
                      we were all noobs once…
                        @sdetweil my test of installer on buster on pi 0, comes up running fine now
                        • W Offline
                          wagon40
                          was able to get it to work. only issues is screensaver continues to active.
                          tried this with no luck
                          sudo nano /etc/xdg/lxsession/LXDE/autostart
                          add the following lines:
                          @xset s noblank
                          @xset s off
                          @xset -dpms
                          Save and close, using the commands CTRL-O and CTRL-X.
                          Go to lightdm.conf:
                          sudo nano /etc/lightdm/lightdm.conf
                          xserver-command=X -s 0 -dpms
                            sdetweil @wagon40
                            @wagon40 I noticed that too.
                            Do this
                            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)"
                            • W Offline
                              wagon40
                              @sdetweil said in PI Zero module issues for this beginner:
                              bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
                              looks like it worked! working on a my-commute issue at this time.
                                sdetweil @wagon40
                                @wagon40 thanks… i’ve copied the same process steps over to the installer… thought I had done that.
