    PI Zero module issues for this beginner
    24 Posts 2 Posters 10.1k Views 2 Watching
      sdetweil @wagon40
      @wagon40 hm… I don’t see that on my pi 0…
      And electron is optional, so there should be no need for chrome driver
      • W Offline
        wagon40
        Same issue I had with the other download. any suggestion?
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
        npm ERR!     /home/pi/.npm/_logs/2020-02-05T22_31_04_266Z-debug.log
          sdetweil @wagon40
          @wagon40 I will have to look. It will be a couple hours. Have grandson now
          • W Offline
            wagon40
            Tried to npm start and it states that i dont have a config.js. went to the desktop and i can navigate to the magicmirror file and open the config sample. not sure why it isnt loading? did a reboot and it is not starting MM.
              sdetweil @wagon40
              @wagon40 because the install didn’t finish… copy config.js.sample to config.js
              can u show me the ~/install.log?
              other things might fail too… as it didn’t complete the install steps…
              i am trying again right now on my pi 0, but on jessie (as thats the OS level I have installed there at the moment)
              • W Offline
                wagon40
                nothing for install.log. tried a few different ways. I was able to make a copy but just a black screen on npm start up. not sure what to do.
                • W Offline
                  wagon40
                  I ran this command and got that
                  npm run config:check
                  npm ERR! code ENOENT
                  npm ERR! syscall open
                  npm ERR! errno -2
                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                  npm ERR! enoent This is related to npm not being able to find a file.
                  npm ERR! enoent
                  npm ERR!     /home/pi/.npm/_logs/2020-02-06T00_34_33_299Z-debug.log
                    sdetweil @wagon40
                    @wagon40 did u run my script? it creates a log file…
                    gotta be IN the MagicMirror folder
                    to get the base config
                    cd ~/MagicMirror/config
                    cp config.js.sample config.js
                    but the system is a mess right now… hang on I am testing a fixed installer…
                    • W Offline
                      wagon40
                      I appreciate your help and putting up with a noob
                      pi@raspberrypi:~/MagicMirror/config $ npm run config:check
                      > magicmirror@2.10.1 config:check /home/pi/MagicMirror
                      > node tests/configs/check_config.js
                      Checking file...  /home/pi/MagicMirror/config/config.js
                      Your configuration file doesn't contain syntax errors :)
                        erase the current MagicMirror folder (rm -rf MagicMirror )
                        and run the install script again , they changed some upstream library to hard fail…
                        but we didn’t need it anyhow…
                          sdetweil @wagon40
                          @wagon40 said in PI Zero module issues for this beginner:
                          we were all noobs once…
                            @sdetweil my test of installer on buster on pi 0, comes up running fine now
                            • W Offline
                              wagon40
                              was able to get it to work. only issues is screensaver continues to active.
                              tried this with no luck
                              sudo nano /etc/xdg/lxsession/LXDE/autostart
                              add the following lines:
                              @xset s noblank
                              @xset s off
                              @xset -dpms
                              Save and close, using the commands CTRL-O and CTRL-X.
                              Go to lightdm.conf:
                              sudo nano /etc/lightdm/lightdm.conf
                              xserver-command=X -s 0 -dpms
                                sdetweil @wagon40
                                @wagon40 I noticed that too.
                                Do this
                                bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)"
                                • W Offline
                                  wagon40
                                  @sdetweil said in PI Zero module issues for this beginner:
                                  bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
                                  looks like it worked! working on a my-commute issue at this time.
                                    sdetweil @wagon40
                                    @wagon40 thanks… i’ve copied the same process steps over to the installer… thought I had done that.
