    PI Zero module issues for this beginner
    24 Posts 2 Posters 8.4k Views 2 Watching
      sdetweil @wagon40
      @wagon40 you should use my installation script… it does it all…
      see here https://github.com/sdetweil/MagicMirror_scripts/blob/master/run-start.sh
      use the desktop version of the pi 0… stretch or buster… jessie is too old
      what modules
      what is installed is folders in ~/MagicMirror/modules
      what is being used , see the ~/MagicMirror/config/config.js, and each module: statement
      where disabled is not specified or disabled: false
      nano is the commandline editor
      ctrl-o to save the file
      ctrl-x to exit
      ctrl-w to search the file
      I had to manually add the configuration I found on the My-commute page so is that normal to have to enter in configuration to the config.js?
      yes. u install the code, then have to update the MM config to actually use it
      • W Offline
        wagon40 @sdetweil
        @sdetweil thank you for the quick reply. I will try your download tomorrow if I get a chance and hopefully have better luck.
          sdetweil @wagon40
          @wagon40 to install MM again, you will need to rename the current folder out of the way
          do this
          cd ~
          mv MagicMirror  MagicMirror.save
          • W Offline
            wagon40
            can you send me the direct script to place in the command line to load your script? I have tried a few bash $( bala bal bal) and im not getting much luck.
            I tried to follow this https://forum.magicmirror.builders/topic/9386/installing-on-a-pi-zero/72
            but of course it wont start. screen goes to sleep and it only starts for a minute then goes to desktop.
            I installed buster with desktop.
              sdetweil @wagon40
              @wagon40 from the page I referenced
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
              you can do that over ssh, or on the pi monitor terminal session
              it will prompt you about autostart with pm2 and turning off screensaver
              • W Offline
                wagon40 @sdetweil
                all was going well until the dependencies stopped it. tired to send the code using </> or :: but it blanks out the submit button?
                • W Offline
                  wagon40 @wagon40
                  @wagon40
                  npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
                  npm ERR!     /home/pi/.npm/_logs/2020-02-05T21_24_22_985Z-debug.log
                  Unable to install dependencies!
                    sdetweil @wagon40
                    @wagon40 hm… I don’t see that on my pi 0…
                    And electron is optional, so there should be no need for chrome driver
                    • W Offline
                      wagon40
                      Same issue I had with the other download. any suggestion?
                      npm ERR! errno 1
                      npm ERR!
                      npm ERR!     /home/pi/.npm/_logs/2020-02-05T22_31_04_266Z-debug.log
                        sdetweil @wagon40
                        @wagon40 I will have to look. It will be a couple hours. Have grandson now
