    PI Zero module issues for this beginner
    24 Posts 2 Posters 9.7k Views 2 Watching
    • W Offline
      wagon40
      was able to get it to work. only issues is screensaver continues to active.
      tried this with no luck
      sudo nano /etc/xdg/lxsession/LXDE/autostart
      add the following lines:
      @xset s noblank
      @xset s off
      @xset -dpms
      Save and close, using the commands CTRL-O and CTRL-X.
      Go to lightdm.conf:
      sudo nano /etc/lightdm/lightdm.conf
      xserver-command=X -s 0 -dpms
        sdetweil @wagon40
        @wagon40 I noticed that too.
        Do this
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)"
        • W Offline
          wagon40
          @sdetweil said in PI Zero module issues for this beginner:
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
          looks like it worked! working on a my-commute issue at this time.
            sdetweil @wagon40
            @wagon40 thanks… i’ve copied the same process steps over to the installer… thought I had done that.
