    Black screen on start up of Magic Mirror
    11 Posts 3 Posters 4.4k Views 3 Watching
    • B
      bkrand95
      Hi everyone, extreme beginner here so please bear with me. I’ve been using my mirror successfully for the past 6-8 months without issues. Just today I attempted to install the NowPlayingOnSpotify module and the install, credentials set-up etc. was all pretty straight forward. Once everything was finally ready I opened MagicMirror to have a look and it was only a blank screen.
      Thinking it was the spotify module I removed that from my config file and still no luck. I even went on to remove the module itself from my module folder but also no luck. After hours of trying different things online I can’t get this figured out. Saw some things about possibly missing a node_helper.js? But I’m not sure how I know mine is missing or how to install it or even what it is. Sorry again, all new to this.
      Additionally, I’ve tried re-installing node.js as well as re-entering the Magic Mirror repository. These also did not work.
      Below is what I get when I try to start:
      pi@raspberrypi:~ $ cd MagicMirror
      magicmirror@2.10.1 start /home/pi/MagicMirror
      ./run-start.sh
      [20:17:22.933] [LOG] Starting MagicMirror: v2.10.1
      [20:17:22.951] [LOG] Loading config …
      [20:17:22.970] [LOG] Loading module helpers …
      [20:17:22.973] [LOG] No helper found for module: alert.
      [20:17:22.976] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read property ‘split’ of undefined
      [20:17:22.979] [LOG] Loading module helpers …
      [20:17:22.981] [LOG] No helper found for module: alert.
      [20:17:22.982] [ERROR] App threw an error during load
      [20:17:22.983] [ERROR] TypeError: Cannot read property ‘split’ of undefined
      at loadModule (/home/pi/MagicMirror/js/app.js:113:25)
      at loadNextModule (/home/pi/MagicMirror/js/app.js:166:5)
      at /home/pi/MagicMirror/js/app.js:168:6
      at loadModule (/home/pi/MagicMirror/js/app.js:151:4)
      at loadModules (/home/pi/MagicMirror/js/app.js:177:3)
      at /home/pi/MagicMirror/js/app.js:223:4
      at loadConfig (/home/pi/MagicMirror/js/app.js:82:4)
      at App.start (/home/pi/MagicMirror/js/app.js:211:3)
      at Object. (/home/pi/MagicMirror/js/electron.js:117:7)
      [20:17:22.985] [LOG] Whoops! There was an uncaught exception…
      [20:17:22.986] [ERROR] TypeError: Cannot read property ‘split’ of undefined
      [20:17:22.994] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [20:17:22.996] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [20:17:23.264] [LOG] Launching application.
      [20:18:07.282] [LOG] Shutting down server…
        sdetweil @bkrand95
        @bkrand95 that looks like a bad config for compliments
        B 1 Reply Last reply
        • B
          bkrand95 @sdetweil
          @sdetweil What is telling you that it is the compliments module? Just trying to understand, thanks.
            sdetweil @bkrand95
            @bkrand95 I added code to the compliments module to support \n (newline) in the compliment text.
            Using the split function.
            The error is split can’t work on an empty string
            So, it sounds like no compliment for the time of day
              sdetweil
              Or there is a problem with a config entry
              • B
                bkrand95 @sdetweil
                Below is my config file (put x’s in place of all the ID’s…). I actually have my compliments module commented out so I’m not sure how that can be an issue.
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	//address: "localhost", // Address to listen on, can be:
                	address: "0.0.0.0",
                	port: 8080,
                	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.10"], // Set [] to allow all IP addresses
                	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
                	ipWhitelist: [],                                                       // or add a specific IPv4 of 192.168.1.5 :
                	language: "en",
                	timeFormat: 12,
                	units: "imperial",
                			module: "alert",
                			//module: "updatenotification",
                			//position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "Calendar",
                				fade: false,
                				fetchInterval: 5000,
                				colored: true,
                				coloredSymbolOnly: false,
                				maximumNumberOfDays: 90,
                						symbol: "calendar-check",
                						color: "#c7ecff",
                						url: "https://calendar.google.com/calendar/xxxxxxxxxxxxxxxxxxxxxxx
                		//	module: "compliments",
                		//	position: "lower_third"
                			module: "currentweather",
                				locationID: "xxxxxxxxx",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                				appid: "xxxxxxxxx",
                			module: "weatherforecast",
                			header: "Weather Forecast",
                				fade: false,
                				locationID: "xxxxxxxxx",  //ID from https://openweathermap.org/city
                				appid: "xxxxxxxxx"
                   			 module: "MMM-Cocktails",
                   			 position: "bottom_center", // Editable footprint - Fits anywhere.
                      				maxWidth: "400px",     // See provided .css file for full customization options
                        			header: "",
                        	//module: 'MMM-Remote-Control',
                        	// uncomment the following line to show the URL of the remote control on the mirror
                        	//position: 'bottom_left'
                        		// you can hide this module afterwards from the remote control itself
                        		//config: {
                        		//    apiKey: ''
                			module: 'MMM-ModuleScheduler',
                				notification_schedule: [
                					// SHUTDOWN AT 07:04AM MON-FRI
                					{notification: 'REMOTE_ACTION', schedule: '04 7 * * 1-5', payload: {action: "SHUTDOWN"}},
                					// SHUTDOWN AT 11:30PM FRI & SAT
                					{notification: 'REMOTE_ACTION', schedule: '30 23 * * 5-6', payload: {action: "SHUTDOWN"}},
                					// SHUTDOWN AT 10:55PM SUN-THUR
                					{notification: 'REMOTE_ACTION', schedule: '50 22 * * SUN-THU', payload: {action: "SHUTDOWN"}}
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "New York Times",
                				showSourceTitle: true,
                				showPublishDate: true
                			disabled: true,
                			module: 'MMM-EARTH-Live',
                			position: 'bottom_center',
                  			  height:"270px",
                   			 width:"480px",
                   			 useHeader: false,                // true if you want a header
                   			 header: "",                      // Change in config file. useHeader must be true
                   			 animationSpeed: 1000,            // fade speed
                		  module: "MMM-NowPlayingOnSpotify",
                		    clientID: "xxxxxxxxx",
                		    clientSecret: "xxxxxxxxx",
                		    accessToken: "xxxxxxxxx",
                		    refreshToken: "xxxxxxxxx"
                  sdetweil @bkrand95
                  @bkrand95 if u comment out a module, you must comment out the braces too,
                  Not like this
                  //  module : "compliments"'
                  That leaves an empty entry in the modules array. Thus the problem
                  You can also disable a module, by adding
                  disabled: true,
                  After the module: statement without commenting anything out
                  Reply Quote 2
                  • B
                    bkrand95 @sdetweil
                    @sdetweil Thanks for the advice, I went ahead and added the “disabled: true” line instead of commenting out the modules. I’ve seemed to have made some progress as I no longer get the black screen, but now I get the familiar message: “Please create a config file. See README for more information.” I have gotten this message before and it’s usual due to an error in my config file, although this time I really can’t find anything. Below is my current config… any errors pop out? Thanks again for all the help.
                     * MIT Licensed.
                    var config = {
                    	address: "0.0.0.0",
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 12,
                    	units: "imperial",
                    			disabled: true,
                    			position: "top_bar"
                    			module: "clock",
                    			header: "Calendar",
                    				fade: false,
                    				colored: true,
                    						color: "#c7ecff",
                    						url: "xxxxx"
                    			disabled: true,
                    				locationID: "xxxxx",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                    				appid: "xxxxx",
                    				fade: false,
                    				locationID: "xxxxx",  //ID from https://openweathermap.org/city
                    				appid: "xxxxx"
                            			header: "",
                    			disabled: true,
                            		    apiKey: ''
                    			module: "newsfeed",
                    				feeds: [
                    			disabled: true,
                      			  height:"270px",
                       			 width:"480px",
                    		    clientID: "xxxxx",
                    		    clientSecret: "xxxxx",
                    		    accessToken: "xxxxx",
                    		    refreshToken: "xxxxx"
                    O 1 Reply Last reply
                    • O
                      OldSunGuy @bkrand95
                      @bkrand95 said in Black screen on start up of Magic Mirror:
                      module: ‘MMM-Remote-Control’,
                      position: ‘bottom_left’
                      The line after MMM-Remote-Control should be a comment,
                      and there should be a comma after the ‘bottom_left’.
                      Reply Quote 1
                        sdetweil
                        And this line will need a trailing comma
                        • B
                          bkrand95
                          Excellent, that was the fix! Thank you both so much for your help, marking as solved.
